Automatic ARMA selection
For posting your own programs to share with others
Felipe
Re: Automatic ARMA selection
Postby Felipe » Thu Nov 09, 2017 9:21 am
Thanks for your answer.
I want the same program, the automatic ARMA selection, but the program posted in this forum consider a regression with constant.
Here:
equation {%eqname}.ls dlog({%dep}) {%regs} {%lagstring} {%mastring}
Where:
 {%regs}
is the constant.
So I want a regression without this parameter
 {%regs}
I thought if I stablished a conditional I could resolve this problem, because I need to avoid a regression without parameters.
The first conditional considers the case without ARMA terms. So the regression is with constant:
if %arstring="ar(0)" and  %mastring="ma(0)" then
      equation {%eqname}.ls(arma=cls, optmethod=legacy) {%dep} {%regs}
endif
The second conditional considers the case with ARMA terms without constant:
if %arstring="ar(1)" or %arstring="ar(2)" or  %arstring="ar(3)" or  %arstring="ar(4)" or %mastring="ma(1)" or %mastring="ma(2)" or %mastring="ma(3)" or %mastring="ma(4)"  then
       equation {%eqname}.ls(arma=cls, optmethod=legacy) {%dep} {%arstring}{%mastring}
endif
But this conditionals doesn't work.
Postby EViews Gareth » Thu Nov 09, 2017 9:22 am
'Create some data.  Delete these first few lines if you want to run on your existing workfile.
create u 1000
series y=nrnd
'Program that calculates the "best" ARMA specification for an equation.  Edit the variables below to match your particular data/setup.
%eqname = "EQ01"   'name of equation object that will be used.
%maxAR = "2"            'maximum number of AR terms
%maxMA = "3"   'maximum number of MA terms
%dep = "Y"   'dependent variable
%regs = " "   'independent variables
%criterion = "@AIC"    'which criterion to use  enter "@AIC" for Akaike, "@schwarz" for Schwarz, and @HQ for Hannan-Quinn
!maxAR = @val(%maxAR)
!maxMA = @val(%maxMA)
close {%eqname}
'create table for storing critical values.
%matname = "crits"
if @isobject(%matname) then
   %matname = "__crits"
      delete {%matname}
   endif
endif
table(!maxar+2,!maxma+2) {%matname}
{%matname}(1,1) = "AR /  MA"
{%matname}.setlines(1) +b
{%matname}.setlines(a) +r
'set sample
smpl @first+!maxAR @last
!mincrit = 1e12  'set the minimum to an artificially large value to begin
'estimate the models
%arstring = ""
for !i=0 to !maxar
   'build up string for AR terms.
   if !i>0 then
      %arstring = %arstring + " ar(" + @str(!i) + ")"
   endif
   %mastring = ""
   for !j=0 to !maxma
      'build up string for MA terms
      if !j>0 then
         %mastring = %mastring + " ma(" + @str(!j) + ")"
      endif
      'estimate equation
      %allregs = %regs + %arstring + %mastring
      if @len(%allregs)>1 then
         equation {%eqname}.ls {%dep} {%regs} {%arstring} {%mastring}
         'capture criterion
         if @upper(%criterion) = "@AIC" then
            !crit = {%eqname}.@aic
         endif
         if @upper(%criterion) = "@SCHWARZ" then
            !crit = {%eqname}.@schwarz
         endif
         if @upper(%criterion) = "@HQ" then
            !crit = {%eqname}.@hq
         endif
         'compare criterion
         if !crit < !mincrit then
            !mincrit = !crit
            !bestAR = !i
            !bestMA = !j
            %bestARstr = %arstring   'store the best ar string
            %bestMAstr = %mastring   'store the best ma string
            {%matname}.settextcolor(@all) black   'table formatting.
            !ii=!i+2
            !jj=!j+2
            {%matname}.settextcolor(!ii,!jj) red
         endif
         {%matname}(!i+2,!j+2) = !crit
         {%matname}(!i+2,1) = !i
         {%matname}(1,!j+2) = !j
      endif
equation {%eqname}.ls {%dep} {%regs} {%bestARstr} {%bestMAstr}
show {%eqname}
show {%matname}
sazad
Residuals from an AR(1) for a number of macroeconomic variables & countries
Postby sazad » Wed Feb 14, 2018 4:24 pm
I have not programmed much in E-views, so not an export. I am trying to obtain absolute values of residuals from an AR(1) model for time series data of more than one macroeconomic variable and country in one go. Attached a test file for just one variable. How can I create a loop to store the abs value for each of the macro variables for each country? Any prompt help is much appreciated.
Many thanks,
Sohel
macro.xlsx
(16.24 KiB) Downloaded 311 times
Return to “Program Repository”
