Likelihood function problem
bqlqbsleb
Postby bqlqbsleb » Fri Sep 15, 2017 6:19 am
i was trying to use LOGl to estimate an EGARCH model, here is my code
@logl logl1
res = er - c(1) - c(2)*var - c(3)*var*D - c(4)*tr
LOG(var) = C(5) + C(6)*ABS(RESID(-1)/@SQRT(var(-1))) + C(7)*RESID(-1)/@SQRT(var(-1)) + C(8)*LOG(var(-1)) + C(9)*op+ C(10)*pe + C(11)*RF
logl1 = log(@dnorm(res/@sqrt(var))) - log(var)/2
However, i get this information
Missing values in @LOGL series at current coefficients at observation 6/02/1989
So, can some experts tell me why and how to solve it?
bqlqbsleb
Re: Likelihood function problem
Postby bqlqbsleb » Fri Sep 15, 2017 6:23 am
sorry, the code is the below
@logl logl1
res = er - c(1) - c(2)*var  - c(4)*tr
bqlqbsleb
Postby bqlqbsleb » Fri Sep 15, 2017 6:27 am
here is the workfile
missing.wf1
(459.5 KiB) Downloaded 208 times
bqlqbsleb
Postby bqlqbsleb » Fri Sep 15, 2017 7:39 am
the starting value is set based on
equation basic.arch(ged, egarch, archm=var) er c tr @ op pe rf
Postby EViews Gareth » Fri Sep 15, 2017 8:20 am
RESID has no data. Are you sure you want it to depend on RESID?
bqlqbsleb
Postby bqlqbsleb » Sat Sep 16, 2017 6:48 am
EViews Gareth wrote:RESID has no data. Are you sure you want it to depend on RESID?
Hi Garath, thanks for your reply.
yes. as for the GARCH (1,1), i would like to add it to the volatility model. i know that Eviews has package to do it in a simple way; however, i need to modify the mean equation in the following procedure.
so, how can i solve it? i have pre-estimated a model and i believe after that estimation, resid should have values.
bqlqbsleb
Postby bqlqbsleb » Sat Sep 16, 2017 6:57 am
I mean EGARCH(1,1)
Users browsing this forum: No registered users and 23 guests
