Model is randomly solved...?
Postby tvonbrasch » Thu Aug 10, 2017 1:01 am
I have a model with about 2000 equations. If I try to solve the model with the commands:
{%model}.solve(o=n)
   freeze(_a1) {%model}.msg
{%model}.solve(o=g)
   freeze(_a2) {%model}.msg
{%model}.solve(o=b)
   freeze(_a3) {%model}.msg
%sp="_results1"
spool {%sp}
{%sp}.append _a1
{%sp}.append _a2
{%sp}.append _a3
the model will not solve. However if I alter the commands to:
{%model}.solve(o=n,v=f, d=d)
   freeze(_a4) {%model}.msg
{%model}.solve(o=g,v=f, d=d)
   freeze(_a5) {%model}.msg
{%model}.solve(o=b,v=f, d=d)
   freeze(_a6) {%model}.msg
   %sp="_results2"
spool {%sp}
{%sp}.append _a4
{%sp}.append _a5
{%sp}.append _a6
the model solves. (see the two attachments).
I find this very strange. Why is this?
ideally, a user should just have to use a "solve" command and the program should by itself try different solution algorithms (and options) to find the one that solves the model. Is this something you can implement?
_results2.txt
(861 Bytes) Downloaded 85 times
_results1.txt
(15.95 KiB) Downloaded 85 times
Re: Model is randomly solved...?
Postby EViews Gareth » Fri Aug 11, 2017 1:31 pm
The first code is doing a static solve (since that it what the model's current default is).
The second code explicitly instructs to do a dynamic solve.
They're completely different processes, so it is not surprising that one works and one doesn't.
Postby tvonbrasch » Wed Aug 16, 2017 11:41 am
Yes, I noticed it after I uploaded the example. Sorry about that.
