logmode
logmode
Postby tvonbrasch » Thu Aug 10, 2017 6:47 am
I am having trouble with the logmode command
when I use the command
logmode(autosave=on,  float) all
i can see some information in the log window when the program is running, but the log window becomes empty when the program finishes. why is this?
Eviews 10 Jul 27
Re: logmode
Postby EViews Steve » Thu Aug 10, 2017 7:18 am
I'm using EViews 10 Aug 7 2017 build and I can't seem to recreate the error. Here's my test program:
create u 10
series x = rnd
Does this cause a problem on your build? If so, try updating to the latest patch.
Re: logmode
Postby EViews Jason » Thu Aug 10, 2017 7:39 am
Can you post more of your program or send it to support@eviews.com?
We are not seeing the reported behavior.
Re: logmode
Postby tvonbrasch » Thu Aug 10, 2017 9:49 am
Eviews 10 Aug 7, that is not official yet, is it?
The version I have is Eviews 10 July 27.
I think the problem is caused by the rgets addin made by Gareth....?
Try the code
close @all
%dir=@runpath
cd  %dir
wfopen .\macrobond
pageselect m
smpl 2002 @last
   rgets(eq=eq_kpi,arlags=1 2 3 4 5 6 7 8 9 10 11 12) dlog(kpi) c
It is as if the rgets command deletes the log-file.
Re: logmode
Postby EViews Steve » Thu Aug 10, 2017 9:58 am
Found the problem.
RGETS internally tries to adjust the logmode. That seems to clear the current log window. I'll look into it and let you know when we have a fix.
Re: logmode
Postby tvonbrasch » Thu Aug 10, 2017 10:09 am
Excellent, thanks!
Users browsing this forum: No registered users and 13 guests
