Is there a simple command to produce a stacked bar chart which sums up to 100%.
My example:
Two series A and B can be pictured by a stacked bar chart, but the total level varies over time and do not sum up to 100% (to 1). In a multiple step procedure I got the favoured results but I guess that there is a simple command.
Do you have suggestions?
The pedestrian version as follows:
[code]
genr total=a+b
genr s_a=a/total
genr s_b=b/total
graph weight.bar(s) s_a s_b
[quote]
Stacked bar chart
Re: Stacked bar chart
There is not a direct EViews command for this. Your current method is probably the easiest.
It's a pity that there is no command, but can be a suggestion for the next version.
(Because in simple Excel Charts it's possible - However I prefer merging various charts in Eviews!)
Users browsing this forum: No registered users and 19 guests
