Creating New Series using conditional
Ricardo98
Postby Ricardo98 » Wed Jun 21, 2017 11:09 am
Hi there,
I would like to create a new series from an existing one called "airtemp". Im trying to get a (airtemp-24)^2 result when the value in "airtemp" exceeds 24; a (16-airtemp)^2 result when the value in "airtemp" is below 16 and "0" otherwise. But the following command is giving me back "Sytax error". Is there anyone that could spot the mistake?
smpl @all
alpha decision=0
smpl if airtemp>24
decision = (airtemp-24)^2
smpl if airtemp<16
decision = (16-airtemp)^2
smpl @all
Thanks so much in advance!
Re: Creating New Series using conditional
Postby EViews Gareth » Wed Jun 21, 2017 11:11 am
You're declaring it as an alpha (which contains strings) and setting it equal to a number.
Either use series instead of alpha, or change the values to be strings (with the @str function).
Ricardo98
Postby Ricardo98 » Wed Jun 21, 2017 1:41 pm
EViews Gareth wrote:You're declaring it as an alpha (which contains strings) and setting it equal to a number.
Hi Gareth,
All done thanks!
Users browsing this forum: No registered users and 15 guests
