Putting limits on estimated coefficient values
Re: Putting limits on estimated coefficient values
I did a logit transformation and want to manually calculate untransformed coefficient value.
I want to verify does @logit(c(2)) = LN(c(2)/(1-c(2))) ?
Thank you.
acemi
Thank you.
acemi
I had looked at the explanation of special functions>logit transformation explanation but cannot map it to how it transforms my c(2).
1/(1+exp(-x))) = exp(x)/(1+exp(x))
c(2) has no relation whatsoever with the expression on LHS..
can elaborate please ?
acemi wrote:I had looked at the explanation of special functions>logit transformation explanation but cannot map it to how it transforms my c(2).
You get 1/(1+exp(-c(2))))
Thank you!
The whole purpose for @logit transformation is to impose/force limits for c(2). For the @logit(c(2)) conversion, the NLS estimation of c(2) is 3,475962 which is clearly not within intended range limits of 0<c(2)<1. So in order to obtain value for @logit(c(2)), substitute this value in 1/(1+exp(-3,475962)) = 0,969996 which is between intended limits. But is it OK to conclude that I have constrained c(2) in this case ?
acemi
acemi
acemi wrote:Thank you!
acemi
In most cases like this people want the coefficient to between 0 and 1, not specifically the parameter c(2). As you say, using @logit does this. So think of the coefficient as being the value of @logit(c(2)).
Is there a way to restrict the parameter c(2) in eviews9 ?Thank you!
startz wrote:acemi wrote:The whole purpose for @logit transformation is to impose/force limits for c(2). For the @logit(c(2)) conversion, the NLS estimation of c(2) is 3,475962 which is clearly not within intended range limits of 0<c(2)<1. So in order to obtain value for @logit(c(2)), substitute this value in 1/(1+exp(-3,475962)) = 0,969996 which is between intended limits. But is it OK to conclude that I have constrained c(2) in this case ?
acemi
The answer is that same as for earlier versions. You cannot restrict c(2) per se, but generally that's not what's desired. Instead, replace every appearance of c(2) with @logit(c(2)).
I am doing the reparameterization shown in this forum to coinstraint my coefficients.
CODE: SELECT ALL
A reparameterization that satisfies these constraints is
CODE: SELECT ALL
I am having an error with my code and I don´t know why. The error is:
Maximum number of iterations exceeded in "OPTIMIZE(MIN)
OPTIVOL(Z1,VDUM,MCOV)" on line 1.
My code is
Please help!
CODE: SELECT ALL
[list]ai > 0 and a1 + a2 + ... + ak = 1[/list]
CODE: SELECT ALL
ai = exp( bi ) / ( exp( b1 ) + exp( b2 ) + ... + exp( bk ) )
My code is
subroutine optivol(scalar !scmvol, vector vdum, matrix mmcov)
scalar sc1=@csum(vdum)
vector(6) wmvol
wmvol(1)=exp(vdum(1))/exp(sc1)
wmvol(2)=exp(vdum(2))/exp(sc1)
wmvol(3)=exp(vdum(3))/exp(sc1)
wmvol(4)=exp(vdum(4))/exp(sc1)
wmvol(5)=exp(vdum(5))/exp(sc1)
wmvol(6)=exp(vdum(6))/exp(sc1)
!scmvol=@transpose(wmvol)*mmcov*wmvol
endsub
vector(6) vdum
vdum=1
scalar z1
optimize(min) optivol(z1,vdum,mcov)
Please help!
I want to estimate this equation:
in a way that ensures that the coefficients are positive. However, I get a "near singular matrix" message when using the @exp function to estimate the equation:
If I instead use the function @abs, there is no singularity issue:
That said, I am wondering if the @abs function is not in general suitable as the derivative is not always defined.
Attached is the workfile with the data.
Can you please take a look and suggest ways to ensure that the coefficients are positive?
t
YK=C(1)*XK1+C(2)*XK2+C(1)*C(2)*XK3
equation _test2.ls YK=EXP(C(1))*XK1+EXP(C(2))*XK2+EXP(C(1))*EXP(C(2))*XK3
equation _test1.ls YK=abs(C(1))*XK1+abs(C(2))*XK2+abs(C(1))*abs(C(2))*XK3
show _test1
t
close @all
wfopen .\exp2.wf1
'first equation - no singularity
show _test1
'second equation - singularity ...?
show _test2s
- exp2.wf1
- (131 KiB) Downloaded 93 times
You are correct on the issue of differentiability of abs. I always use the exp function but you have to make sure starting values are appropriate. What are the values when you have issues?
[edit:]
I spent a little more time looking at this. I downloaded the workfile and ran the example at various starting values. I get singularity in all cases because the estimation is driving the coefficients on XK2 to zero (e.g., C(2) is a very large negative number after a few iterations) which I am pretty certain is giving you zero gradients for C(2) and hence, singularity.
As a sanity check, I did a quick simulation of the model and then estimated the coefficients for the simulated data
and the estimation produces sensible results.
At this point, I'd say that it looks to be a data issue, not a specification issue. Along these lines, note that the unrestricted linear regression produces estimated coefficients on XK2 and XK3 that are both negative values.
[edit:]
c(1) = .5
c(2) = -1
series z = exp(c(1))*xk1 + exp(c(2))*xk2 + exp(c(1)+c(2))*xk3 + 10*nrnd
nrnd(c)
equation eqtest.ls z = exp(c(1))*xk1 + exp(c(2))*xk2 + exp(c(1)+c(2))*xk3
Thanks for looking into this, Glenn. I will take a second look at the data.
t
t
Users browsing this forum: No registered users and 32 guests
