Conditional VAR forecast
dakila
Postby dakila » Tue Jul 05, 2016 9:23 pm
This thread is about the confcast add-in that performs a conditional VAR forecast.
Andrew25
Re: Conditional VAR forecast
Postby Andrew25 » Wed Jul 06, 2016 6:25 am
There seems to be some problems with the link - when I click to download comfcast add-in, I get redirected to the Eviews frontpage. Also tried to download from the built-in add-in manager and still get error message.
Postby EViews Gareth » Wed Jul 06, 2016 7:36 am
Try now.
dakila
Postby dakila » Sat Jul 16, 2016 8:49 pm
Hi Andrew,
How did it go?
cyp74
Postby cyp74 » Sun Jul 17, 2016 9:30 pm
I couldn't install it. It says the installer is missing.
dakila
Postby dakila » Sun Jul 17, 2016 11:02 pm
What is your Eviews version?
cyp74
Postby cyp74 » Mon Jul 18, 2016 12:22 am
9.5
dakila
Postby dakila » Mon Jul 18, 2016 2:12 am
You are right. Gareth, could you check this add-in?
However you can manually install it. Just go confcast directory and open "confcast install.prg"
Postby EViews Gareth » Mon Jul 18, 2016 8:38 am
Try now.
(the .toc file was incorrect).
cyp74
Postby cyp74 » Tue Jul 19, 2016 1:14 am
All good, thanks
xprimexinverse
Contact:
Postby xprimexinverse » Wed Nov 23, 2016 7:07 am
I would like to know more details about the method used in the add-in. The program file is encrypted and the documentation, while citing two papers, is not very clear and quite short. Could additional information please be provided; for example, in terms of extended technical documentation or, better yet, open code?
And, many thanks for what should prove to be a very useful add-in! Top job.
Cheers,
Graeme
dakila
Postby dakila » Sat Nov 26, 2016 12:36 am
Thanks for your comment, Graeme. I attached the technical appendix. If time permits I will post the detailed explanation on the blog.
Conditional forecasting.pdf
(302.78 KiB) Downloaded 732 times
paolo.zanghieri
Postby paolo.zanghieri » Thu Mar 30, 2017 7:22 am
I have two problems with the add in:
1) I first tried to use it via the menu and, even though I constrain just one variable for one quarter I get an error message saying that "Matrix-Vector index is out of range" moreover, I get the forecast charts even though I did not ask for them
2) I try to use the command line, but apparently it is not possible to locate the .prg file
I have the 9.5 version Mar 2 2017 build. Any clue?
thanks
dakila
Postby dakila » Fri Mar 31, 2017 12:08 am
I have no idea. Could you post the file?
paolo.zanghieri
Postby paolo.zanghieri » Tue Apr 04, 2017 4:09 am
Sure,
here it is.
Thanks a lot
us_bvar.wf1
(4.06 MiB) Downloaded 430 times
Return to “Add-in Support”
