Eviews 7 installation mac
ttduo8
Postby ttduo8 » Tue Mar 14, 2017 11:05 pm
I try to download the eviews 7 for mac but then I can not open to install the software on my macbook air. Could you help me to solve that?
Thank you,
Best regards,
Re: Eviews 7 installation mac
Postby EViews Steve » Tue Mar 14, 2017 11:19 pm
Right click the pkg file and click Open.
Sent from my iPhone using Tapatalk
ttduo8
Postby ttduo8 » Wed Mar 15, 2017 2:25 am
I alr try but still can't open it
Thank you,
Postby EViews Steve » Wed Mar 15, 2017 8:13 am
Ok, here are some more detailed instructions...
First, verify that the EViews9SV.dmg file you downloaded is approximately 370MB in size.
Screen Shot 2017-03-15 at 7.56.04 AM.png (74.02 KiB) Viewed 9434 times
If you double-click the DMG file and it opens into a window like this, it should be fine.
Screen Shot 2017-03-15 at 7.56.32 AM.png (332.83 KiB) Viewed 9434 times
Now if you simply double-click the EViews 9 Student Version.pkg icon, you might see a dialog like this:
Screen Shot 2017-03-15 at 7.56.57 AM.png (59.43 KiB) Viewed 9434 times
Click the OK button to close this dialog. Then hold down the Control key and click on the "EViews 9 Student Version.pkg" icon again. This should bring up the menu (holding down the Control key and clicking is the same as right-click if you have a two-button mouse). Click on Open on the menu. You should now see a dialog like this:
Screen Shot 2017-03-15 at 7.57.25 AM.png (61.52 KiB) Viewed 9434 times
Click the Open button to start the installation. The first window of our installer should look like this:
Screen Shot 2017-03-15 at 7.57.51 AM.png (113.37 KiB) Viewed 9434 times
Click Continue to begin the installation process.
If you are still having trouble with our installer, please send me the error message you are seeing. You can take a screenshot on your mac by clicking Cmd-Shift-4, then tap the spacebar (your mouse icon should turn into a camera now), then click on the window you'd like to copy. This will save the screenshot as a PNG file on your OSX desktop. Insert the PNG file as an attachment to your reply here.
Postby EViews Steve » Wed Mar 15, 2017 8:33 am
By the way, I don't believe EViews 7 SV Mac will run on the latest OSX version (Sierra). It may not even run on El Capitan. So even if you were able to install it you might need to upgrade to EViews 9 SV Mac in order to actually run it successfully.
ttduo8
Postby ttduo8 » Wed Mar 15, 2017 12:55 pm
Thank you so much
