frenchdata - Ken French's data library
EViews Rebecca
Postby EViews Rebecca » Fri Feb 24, 2017 11:57 am
This thread is about the frenchdata add-in that fetches data from Ken French's data library and parses it into EViews workfiles.
tmly
Re: frenchdata - Ken French's data library
Postby tmly » Wed Apr 24, 2019 8:33 am
Hi, I am using Eviews 10 Enterprise Edition 64 bit. I have installed the frenchdata add in. I have changed the alpha truncation max length to 5000 in general options. However when I try to import most large portfolios I get the attached error. For instance on the 6 portfolios formed on size and Book-To-Market (2x3). This error occurs on most portfolio data imports. Why is this and does anyone know how to fix it? Thanks. Tom
EViews Rebecca
Postby EViews Rebecca » Tue May 07, 2019 1:45 pm
I don't get this error. Can you check that you are up to date (Help -> EViews Update)?
paolo.zanghieri
Postby paolo.zanghieri » Fri Feb 14, 2020 6:57 am
I cannot dowload the add in. I get a message with "Unknown error". I am using version 11 6v bits.
thanks
Postby EViews Steve » Fri Feb 14, 2020 8:02 am
If you ever have trouble downloading an add-in, you can always hit the "Website" button and go to the following page to download the add-in directly:
http://www.eviews.com/Addins/addins.shtml
From that page, I got the following download link for the frenchdata add-in:
http://www.eviews.com/Addins/frenchdata.aipz
Once you've downloaded the AIPZ file, you can drag it onto EViews to start the installation process.
Return to “Add-in Support”
