Problem with include in if-statement
pelleenglund
Postby pelleenglund » Thu Nov 17, 2016 5:07 am
Hello!
I sometimes use "Include" to include another EViews-program in a main EViews-program. It works just fine except when you use it in an if-statement, for example like this
If ..... Then
Include "C:\Temp\Example.prg"
EndIf
Then you get the error message "Endif found outside of loop or IF statement". The code will run without error if you include it without putting it in the if-statement, and it works fine if you change "Include" to "Run" or "Exec" instead.
I just wonder if this may be a bug?
Best regards,
Pelle
Re: Problem with include in if-statement
Postby EViews Gareth » Thu Nov 17, 2016 5:17 am
Probably just the way you have the included program written.
It is easy to show that in general it works ok:
myfile.prg:
series a = @nrnd
parent program:
create m 1990 2000
if 3>2 then
include myfile.prg
endif
pelleenglund
Postby pelleenglund » Thu Nov 17, 2016 6:20 am
Well, I have tried to write the code in different ways (for example with and without "" around the program that should be included) but it doesn't work. Thanks anyway, and it is okey since I can always use "Run" instead.
Best regards,
Pelle
