When using point-and-click we can transform all variables in a group (or a series) using the drop-down menu that says Default, %Year Change, etc...
Is there a way to do this directly via code command? Is there such a method for groups?
Thanks!
Group Data Transformation - Code Command
Re: Group Data Transformation - Code Command
When using that drop down you are not transforming the variables - you're changing the display of the variables without changing the variables themselves.
That said, if you want to change the display via command, the group.sheet command has options to control the display transformation.
Changing the display would suffice to create a frozen graph with the appropriate transformations?
Users browsing this forum: No registered users and 11 guests
