Nowcasting GDP
Moderators: EViews Gareth, EViews Moderator, EViews Chris
Andrew25
Nowcasting GDP
Postby Andrew25 » Thu Jun 16, 2016 6:02 am
I am using Bayesian VAR to nowcast GDP and financial sector output, however I have some issues. I will try to describe it step-by-step. First, I estimate the model with data from 1996q1 to 2015q4, then I make model and obtain forecasts for 2016q1 using Dynamic-Deterministic simulation. Until this point, everything is fine. However, as I have 2016q1 data for some of the variables included in the model, I create alternative scenario and override the values for 2016q1 with the data I have. However, when I compare the forecasted values of GDP from this scenario with baseline forecasts there is no change. What am I doing wrong? I will greatly appreciate your comments!
Re: Nowcasting GDP
Postby EViews Gareth » Thu Jun 16, 2016 6:08 am
Need the workfile probably
Andrew25
Re: Nowcasting GDP
Postby Andrew25 » Thu Jun 16, 2016 6:49 am
Here is the workfile. Thank you Gareth very much for looking into these matters!
Nowcast WF.wf1
(110.09 KiB) Downloaded 141 times
Re: Nowcasting GDP
Postby EViews Gareth » Thu Jun 16, 2016 10:07 am
I think none of the remaining endogenous variables depend upon the overriden/excluded variables in the same time period - they all depend on past values. So the forecasts will only change for a forecast of 2016q2 onwards.
Andrew25
Re: Nowcasting GDP
Postby Andrew25 » Fri Jun 17, 2016 5:21 am
Maybe you have some advice how I can make the remaining endogenous variables depend on the overriden variables in the same period?
Re: Nowcasting GDP
Postby EViews Gareth » Fri Jun 17, 2016 7:26 am
Change the specification of the underlying relationships
Andrew25
Re: Nowcasting GDP
Postby Andrew25 » Wed Jun 29, 2016 2:56 am
Seems that I found the solution - variables for which data are available are specified as exogenous in VAR dialog!
dakila
Re: Nowcasting GDP
Postby dakila » Mon Jul 04, 2016 4:04 am
You do not need to make some variables exogenous forcefully. It is not good idea. You can use the confcast add-in.
Andrew25
Re: Nowcasting GDP
Postby Andrew25 » Mon Jul 04, 2016 4:56 am
Dear Dakila, thank you very much for answer. However, where can I download the confcast add-in? It isn't listed there http://www.eviews.com/Addins/addins.shtml
dakila
Re: Nowcasting GDP
Postby dakila » Mon Jul 04, 2016 1:29 pm
Sorry. You need to wait. It is new add-in. I hope Eviews will post it soon on the web.
dakila
Re: Nowcasting GDP
Postby dakila » Sat Jul 16, 2016 8:51 pm
Hi Andrew,
How did you find it?
Return to “Models”
