Basic Rolling Regression
For posting your own programs to share with others
gsourop
Re: Basic Rolling Regression
Postby gsourop » Wed Nov 11, 2015 3:15 pm
I denote with asterisks "***" the corrections made. Is this correct?:
' set window size
!window = 90
' set step size
!step = 1
' get size of workfile
!length = @obsrange
' declare equation for estimation
equation eq1
'calculate number of rolls
!nrolls = @floor((!length-!window)/!step)
'matrix to store coefficient estimates
matrix(2,!nrolls) coefmat ' where 2 is the number of coefficients
'series to store forecast estimates
series fcast
' set sample for estimation period
%start ="@first" ' @otod(@ifirst(ser))
%end="@last" '@otod(@ilast(ser))
'smpl {%first} {%last}
'variable keeping track of how many rolls we've done
!j=0
' move sample !step obs at a time
!j=!j+1
%first = @otod(@dtoo(%start)) '****
%last = @otod(@dtoo(%start)+!i+!window-2)
' estimate equation - where the equation is y=c(1) + c(2)*x1
eq1.ls log_spot c (log_ipi_uk-log_ipi_us)
'store coefficients
colplace(coefmat,eq1.@coefs,!j)
' 1-period-ahead forecast
%1pers = @otod(@dtoo(%start)+!i+!window-1) 'start point
%1pere = @otod(@dtoo(%start)+!i+!window) 'end point
'*EDITED
if @dtoo(%end) < @dtoo(%1pere) then 'check whether the forecast end point is greater than the workfile end point
exitloop
endif
' set smpl for forecasting period
smpl {%1pers} {%1pere}
' forecast with command *forecast* (see also *fit*)
eq1.forecast(f=na) yf
' set sampl to obtain the 4th period observation
smpl {%1pere} {%1pere}
' store forecasts
fcast = yf
smpl @all
show coefmat
show fcast.line
d(noerr) yf
gsourop
Postby gsourop » Thu Nov 19, 2015 4:26 pm
Hi everyone,
I want to estimate a Random Walk model under a recursive window (expanding). My observations are from 1973M01 to 2014M12, and sum into 504 observartions (from which I want to exclude the first 12 from my sample-I just used them to calculate the inflation rate). I want my first estimation to start at 1978M01, and take into account the observations from 1974M01 until 1977M12. Until now I have made the above:
' set window size
!window = 60
' set step size
!step = 1
!length = @obsrange
equation eq1
series fcast
!j=0
!j=!j+1
%first = @otod(@dtoo(%start)) '+!i-1)
' estimate equation - where the equation is y=ut
eq1.ls d(lspot) lspot(-1)
'store coefficients
'*EDITED
exitloop
endif
' store forecasts
fcast = yf
smpl @all
show coefmat
show fcast.line
d(noerr) yf
If I want to do the same with a Taylor rule, let's say the following specifications: I-I* = (infl-infl*)+(output_gap-output_gap*) , the "*" is for the foreign country, I will have to reestimate the output gap for every new estimation that come as I expand my window. Does anyone know how can I do that?
Thank you for your time!
Priyabrata
Postby Priyabrata » Mon Jun 06, 2016 9:27 pm
I wrote this command in the command window to find rolling coefficients of the regression pca1 c usbe10 ustips10. But unfortunately I couldn't find the results. I ve no basic training in programming language. Please advice. Thanks a lot.
!window = 24
!step = 1
!length = @obsrange
equation eq1
!nrolls = @round((!length-!window)/!step)
matrix(3,!nrolls) coefmat
!j=0
!j=!j+1
smpl @first+!i-1 @first+!i+!window-2
eq1.ls pca1 c usbe10 ustips10
show coefmat
Postby EViews Gareth » Mon Jun 06, 2016 9:51 pm
You have to use a program (file->new program) rather than the command window
Priyabrata
Postby Priyabrata » Mon Jun 06, 2016 10:44 pm
Hi Gareth,
Thanks a lot for such prompt response.
When I run the new program, it says that "Next found outside of loop or IF statement"
Please suggest.
Postby EViews Gareth » Mon Jun 06, 2016 11:05 pm
The line that starts with !i=1 is missing a for
Priyabrata
Postby Priyabrata » Mon Jun 06, 2016 11:23 pm
Thanks a lot Gareth. It worked.
ahamm23
Postby ahamm23 » Thu Jul 07, 2016 12:01 pm
Hi everyone.
So I am trying to forecast the volatility of the S&P 500 and S&P 100 and I need to create a in and out of sample forecast using a rolling regression. However this is my first time using EVIEWS and was wondering what I will need to do before conducting the Roll regression.
At this moment in time, I've collected my data and I have imported it into my EVIEWS workbook and made them into logs. What is the next step for me ? what equation do I need to make? what is the basic roll regression code?
Any help would be much appreciated!
Thank you.
tonach
Postby tonach » Mon Nov 14, 2016 10:05 am
Hello , I need some help trying to make this rolling in a 156 data moving window, I need to adjust the start and end point so each regression takes 156 observations , any help is appreciated ,regards
'run rolling regression
' set window size
!window = 156
' set step size
!step = 1
!length = @obsrange
equation eq1
matrix(3,!nrolls) coefmat ' where 3 is the number of coefficients
!j=0
!j=!j+1
' set sample to estimation period
' estimate equation - where the equation is y=x1 x2 x3
eq1.ls y x1 x2 x3
'store coefficients
show coefmat
Postby EViews Gareth » Mon Nov 14, 2016 7:15 pm
Looks ok to me.
tonach
Postby tonach » Tue Nov 15, 2016 5:21 am
The regressions seems not be to be a 156 window. I think I need to set an @first and @last to tell Eviews to make a regression of a moving 156 window.
For example, I woulld like something like
reg1 : 2010m01 - 2016m01
reg2 : 2010m02 - 2016m02
reg3 : 2010m03 - 2016m03
so the window remains the same, regards
Postby EViews Gareth » Tue Nov 15, 2016 6:58 am
That's what it is doing.
saadallah
Postby saadallah » Tue Dec 13, 2016 5:10 am
Hello Gareth,
Thank you for the code.
I'm interested by running a rolling regression (with one explanatory variable) but for 35 stocks.
I have 35 stocks (Y1,Y2...Y35) and one market index (X).
Is it possible ?
Thank you
Postby EViews Gareth » Tue Dec 13, 2016 7:57 am
You'll have to write a loop that loops over the stocks and runs the regression on each.
saadallah
Postby saadallah » Tue Dec 13, 2016 8:34 am
thank you for your reply.
I see how to write a loop that loops over the stocks and runs a simple regression but i don't see how to do it with a rolling regression.
I don't see how to do it.
can you give me a simple example?
Return to “Program Repository”
