Command capture sometimes captures incorrect syntax
CharlieEVIEWS
Postby CharlieEVIEWS » Tue Feb 23, 2016 2:58 pm
See subject. E.g adding legend:
amountandfreq_bar.setelem(1) "legend(Amount To Supplier)"
amountandfreq_bar.setelem(2) "legend(# Payments to Supplier)"
should naturally be:
amountandfreq_bar.setelem(1) legend("Amount To Supplier (Left)")
amountandfreq_bar.setelem(2) legend("# Payments to Supplier(Right)")
and:
amountandfreq_bar.axis(l) prefix='£'
should be:
amountandfreq_bar.axis(l) format(prefix="£")
Have noticed a couple of other small things here and there too.
Charlie
Re: Command capture sometimes captures incorrect syntax
Postby EViews Gareth » Tue Feb 23, 2016 3:44 pm
Please let us know whenever you spot one - they're usually pretty trivial to fix once we know about them!
Postby EViews Jason » Mon Feb 29, 2016 11:18 am
I am not seeing the described behavior for #1. I see
amountandfreq_bar.setelem(1) legend(Amount To Supplier)
which correct. What is the build date of your EViews copy (help->about EViews)?
#2 will be fixed in the next patch
CharlieEVIEWS
Postby CharlieEVIEWS » Wed Apr 06, 2016 7:20 am
Sorry Jason - just seen this.
I found another one: When attempting to write an equation to disk, CC gives me:
{%equation}.save(options)
when entered into the command line it says "save is not a valid view".
Postby EViews Gareth » Wed Apr 06, 2016 7:38 am
What does "write an equation to disk" mean?
CharlieEVIEWS
Postby CharlieEVIEWS » Wed Apr 06, 2016 8:02 am
Object --> View object --> Save table to disk.
Works fine from the menu, but just spits out the wrong capture.
Postby EViews Gareth » Wed Apr 06, 2016 8:03 am
Ah, right. There is no way to do that via command, so we should probably just disable it from all objects other than table objects.
CharlieEVIEWS
Postby CharlieEVIEWS » Wed Apr 06, 2016 8:04 am
Yeah -- I just ended up freezing the equation and .saving it out.
CharlieEVIEWS
Postby CharlieEVIEWS » Wed May 11, 2016 2:27 pm
Capturing sorting on an <alpha_name> gives you
<alpha_name>.sort
when it should be:
sort <alpha_name>
Users browsing this forum: Google [Bot] and 2 guests
