Time varying SVAR
dakila
Time varying SVAR
Postby dakila » Wed Mar 02, 2016 2:48 pm
This thread is about the tvsvar add-in that estimates time varying structural VARs.
Nas1
Re: Time varying SVAR
Postby Nas1 » Fri Mar 04, 2016 4:24 am
thank you for posting the add-in.
why I am getting the message of "out of memory" error. is this mean that I am having a problems in the matrix? I am using a three randomly generated data; the number of data 200. the number of gibbs sampling iteration 10000 and number of burn-in draws 2000. everything else is as default.
I am using eviews 9 with latest update was in November 2015.
another point, please clarify what is Date selection vector really mean?
Kind regards,
dakila
Postby dakila » Fri Mar 04, 2016 10:28 pm
1. Why did you use randomly generated data?. There is an example data in the tvsvar folder if you want to test this add-in. I don't know why you getting this error. I guess this is because of your computer.
2. The tvsvar estimates time varying structural VARs. So you can get impulse response function for any date you want. If you want the impulse responses for 1980q1, 1999q3 and 2007q4, just insert 1980q1 1999q3 2007q4 on the box with no comma.
Nas1
Postby Nas1 » Sun Mar 06, 2016 4:06 am
Thank you so much for answering my inquiry concerning Date selection vector .. the adds in was already uploaded and I did not notice the example in the forum, thats why I used a randomly generated data to check the adds in.
Do you know how to integrate Convergence Diagnostics test and the marginal likelihood estimation in TVP VAR ?
Kind regards,
dakila
Postby dakila » Sun Mar 06, 2016 7:34 am
Sorry, I don't know.
nadybe
Postby nadybe » Wed Mar 30, 2016 8:01 am
hello everyone,
I tried the TVSVAR Add in with my data in first-differences and it return a near singular matrix. Do you know how to fix this issue?
Does anyone have informations on preliminary analysis before using the time varying SVAR?
Thank you
dakila
Postby dakila » Wed Mar 30, 2016 3:25 pm
try to estimate with data in level or annual growth.
wjgatt
Postby wjgatt » Wed Apr 20, 2016 6:52 am
Hi, thanks for this great add-in.
Is it possible to save all the results as series, so that they can be exported? The program which runs the add-in is encrypted, so I cannot modify the code to have Eview save the results as series for example.
W
dakila
Postby dakila » Wed Apr 20, 2016 4:30 pm
Yes. It is possible. I will release version 2.0 soon.
wjgatt
Postby wjgatt » Wed Apr 20, 2016 10:34 pm
Awesome, thank you!
Roody36
Postby Roody36 » Tue Jun 21, 2016 2:17 am
When I run the example on the SVAR - the error "Matrix-Vector index is out of range" occurs - Do you happen to know what might be the reason?
dakila
Postby dakila » Tue Jun 21, 2016 9:34 pm
Which version do you use? Probably you use the older version. I think you need to upgrade your Eviews to version 9.
Roody36
Postby Roody36 » Wed Jun 22, 2016 12:50 am
Well you may be right , I use Eviews 8 - The add-in is compatible only with higher version?
dakila
Postby dakila » Wed Jun 22, 2016 3:17 am
Yes
pascalle
Postby pascalle » Tue Jul 05, 2016 10:18 am
I am using eviews 8 to estimate the TVC-SVAR model with monthly data 2000m1 to 2015m12. There was an error message: "Sizes do not match in matrix function" during estimation. May I know how can I fix this problem? And what does the "y01" represent?
I find many papers using 40 as a training sample. what does training sample mean? Is there any test to measure it?
Thank you.
Return to “Add-in Support”
Users browsing this forum: No registered users and 29 guests
