VIF analysis in Panel data
eljayski
Re: VIF analysis in Panel data
Postby eljayski » Tue Mar 31, 2015 2:04 pm
saizal87 wrote:You can actually test for multicollinearity based on VIF on panel data. lets say the name of your equation is eq01, so type "eq01.varinf" and then click enter. then you will get centered (with constant) vif and uncentered (without constant) vif. Keep in mind, if your equation dont have constant, then you will only get the uncentered.
this is kool info for me! but, what is the syntax? that is, where, or what screen, within eviews do i type in the name of my model, followed by .varinf?
help gratefully appreciated! eljayski
EconometricAarhus
Postby EconometricAarhus » Tue Aug 04, 2015 12:56 pm
When having a constant in a regression does it then only make sense to look at the centered? It seems like there is a huge difference. I have correlation up to 70%. Does it make most sense to ommit some variables or just be in mind of possible multicolinarity?
Best regards.
Skærmbillede 2015-08-04 21.50.05.png (119.65 KiB) Viewed 6732 times
Max
Postby Max » Wed Oct 28, 2015 3:22 am
Does anyone know if this is appropriate to use that method for panel data? I am confused because in 2008 Eviews Gareth said
EViews Gareth wrote:ok, VIFs shouldn't be available for panel equations :D
I was wondering if the output I have when using eq01.varinf makes sense now under Eviews 8 ?
Lalan_dk
Postby Lalan_dk » Wed Jun 10, 2020 11:12 pm
startz wrote:
khor1984 wrote:The reason i test for multicollinearity is to check whether there is correlation between my variables.. is there any test that i can use for testing multicollinearity in panel data? or, we are assuming no multicollinearity in panel data?
Why do you care whether there is correlation between your variables? There almost certainly is correlation, but that's what OLS is built to sort out.
Hey startz, can you give references about ignoring multicollinearity?
Postby startz » Thu Jun 11, 2020 6:12 pm
Wooldridge, section 3.4 writes
Since multicollinearity violates none of of our assumptions, the "problem" of multicollinearity is not really well defined.
The best reference is Goldberger (1991), but I'm afraid my copy is under lockdown in my office.
Users browsing this forum: No registered users and 7 guests
