Gregory-Hansen Cointegration Test
For posting your own programs to share with others
llenk01
Re: Gregory-Hansen Cointegration Test
Postby llenk01 » Wed Sep 02, 2015 5:16 am
Hello there,
I am using the Gregory Hansen Test to look for relationships between four European stock markets (UK, France, Germany and Spain) and US. I am testing the relationship in pairs and weirdly I am getting the same results when testing with the same dependent variable (please see the attached photo). For example I have the same result for the following pairs US-Spain, UK-Spain, Germany-Spain, France-Spain. Any idea why? Is the test valid at all?
Here is a part of the formula:
group group1
group1.add lnfr
call greghansen(lnes,group1,4,"aic",6)
trubador
Did you use forum search?
Postby trubador » Wed Sep 02, 2015 7:14 am
Hard to say without seeing the workfile.
llenk01
Postby llenk01 » Wed Sep 02, 2015 7:40 am
Hi Trubador,
Please see the attached file.
econometrics ii project.wf1
(363.05 KiB) Downloaded 323 times
llenk01
And the program attached
gh02.prg
(4.77 KiB) Downloaded 341 times
trubador
Postby trubador » Thu Sep 03, 2015 2:04 am
llenk01 wrote:Hello there,
group group1
group1.add lnfr
Each time you run the code, you populate group1 with additional dependent variables. Make sure that you drop the second dependent variable after each run. The following snippet of code might be more useful:
mode quiet
%y1 = "lnes"
%y2 = "lnfr"
group x.add {%y2}
call greghansen({%y1},x,4,"aic",6)
x.drop {%y2}
'... [rest of the program]
llenk01
Postby llenk01 » Thu Sep 03, 2015 10:01 am
Thanks for your help Trubador.
So in my case I use group "group1" instead the "x" in the suggested code..? weirdly I can run the program with "x" as well as "group1" but the x folder in my workfile is empy..
mode quiet
%y1 = "lnes"
%y2 = "lnfr"
group group1.add {%y2}
call greghansen({%y1},group1,4,"aic",6)
group1.drop {%y2}
My new results look much better. I used first country in each row as independent variable which I thought is the right think to do.. Would you suggest otherwise?
trubador
Postby trubador » Thu Sep 03, 2015 1:14 pm
llenk01 wrote:So in my case I use group "group1" instead the "x" in the suggested code..? weirdly I can run the program with "x" as well as "group1" but the x folder in my workfile is empy..
That is because we empty the group after we are done. Otherwise it would keep adding new variables:
group1.drop {%y2}
llenk01 wrote:I used first country in each row as independent variable which I thought is the right think to do.. Would you suggest otherwise?
Since this is a cointegration analysis, it should not matter. However, you can always try the other way around to see if there is a significant change in the results.
llenk01
Postby llenk01 » Fri Sep 04, 2015 2:55 am
Thanks again Trubador - I am really happy with the outcome and the results.
nhuphuong114
Postby nhuphuong114 » Thu Sep 10, 2015 12:54 am
Dear Mr. Trubador!
Plese kindly help me fix the error " Near Singular matrix error". Regressor maybe perfectly collinear in "DO_GHC.LS YC (@trend > 43-2)G". I attached my Work file and GH test code below.
Thank you in advance for your prompt attention! I'm looking forward to hearing from you soon!
Best Regards!
Phuong Ha
gh test.prg
(4.79 KiB) Downloaded 325 times
phase iv.wf1
(30.36 KiB) Downloaded 305 times
trubador
Postby trubador » Fri Sep 11, 2015 3:16 am
One of your variables (lex) is causing the problem. There is nothing I can do about it.
nhuphuong114
Postby nhuphuong114 » Fri Sep 11, 2015 8:18 am
trubador wrote:One of your variables (lex) is causing the problem. There is nothing I can do about it.
Thank you for your advice! But when I remove the variable lex, this error still appears. Please kindly help me if removing the lex can make the GH test workable.
Best Regards!
Phuong Ha
trubador
Postby trubador » Sat Sep 12, 2015 10:31 am
You need to empty the group after you are done. See the previous thread: posting.php?mode=reply&f=15&t=976#pr45243
jug
Postby jug » Thu Oct 29, 2015 2:04 am
First of all, thank you for enabling GH cointegration test add-in for Eviews.
I just have one (fairly technical) question regarding break dates. Does the identified date refer to the last date of the old regime or the first date of the new regime?
I understand that Eviews generally (for instance for unit root tests with breakpoint) defines break date as the first date for the new regime. I was just wondering weather this is also the case for GH cointegration test?
trubador
Postby trubador » Fri Oct 30, 2015 5:16 am
First date of the new regime.
jug
Postby jug » Mon Nov 02, 2015 12:52 am
Thank you.
Cheers.
Return to “Program Repository”
