Multiple rows in R code
cantagallo
Postby cantagallo » Thu Jul 30, 2015 7:42 am
I would like to know if there is a way to run several lines of R code using the Statconn interface, without adding for each line the "xrun". But ideally just once.
Thank you in advance.
Re: Multiple rows in R code
Postby EViews Gareth » Thu Jul 30, 2015 7:45 am
Nope.
Postby startz » Thu Jul 30, 2015 8:21 am
Although you can put multiple R commands in one line separated by semicolons.
cantagallo
Postby cantagallo » Thu Jul 30, 2015 9:14 am
Thanks, it's better than nothing.
What about R libraries? Should I call them in the Eviews code or is it sufficient having them installed?
Postby EViews Gareth » Thu Jul 30, 2015 9:27 am
You generally need to load a library in R:
xrun library(libname)
cantagallo
Postby cantagallo » Tue Aug 04, 2015 10:30 am
jacarandas
Postby jacarandas » Sun Nov 12, 2017 4:18 pm
Hi!
Just wondering if the latest EViews 10 support multiple rows in R code to be run without having to put xrun in each line?
For example, would it be possible to run an entire R script in EViews using a single line command to call for it?
Cheers
Postby EViews Gareth » Sun Nov 12, 2017 5:13 pm
Return to “Add-in Support”
