HDecomp (historical decomposition)
Re: HDecomp (historical decomposition)
In the help document it says:
Resulting matrix will have (k*(k+1)) columns, k being the number of variables. Columns k*(i-1)+i will represent the base projections for ith variable and k columns next to these projections will include the impact of each shock to that variable.
So, the order of structural shocks do not change...
Thanks for your clarifications.
I conducted an SVAR in eviews using three variables: government revenue, government expenditure and gdp using the methodology of Blanchard and Perotti (2002).
In order to measure the government spending shocks would it be correct to take the structural residuals from the historical decomposition addin? Or should one of the variables from the histmat be taken?
I am using eviews 8,
thank you!
thank you!
dtideman wrote:In order to measure the government spending shocks would it be correct to take the structural residuals from the historical decomposition addin?
Yes, you should use histdecomp add-in and check the related box to obtain the structural residuals.
Hello Trubador,
You have indeed made a very useful add-in for people like me working on VAR and SVAR. I have a question to ask, though. In the first study of my research work, I am estimating a SVAR with 9 variables. One of these variables is a monetary policy variable. Now in my second study, I want to estimate the impact of monetary policy shock (estimated from the first study) on firm level output. Using the HDecomp add-in, I was able to retrieve the structural shocks. But If I specifically want to retrieve the monetary policy structural shock to be used in the second study, how to do it- Right now I am getting 9 monetary policy structural shocks (one for each of the 9 variable used in my model). How to decide, which of these monetary policy shock to use?
Parul
Parul
parulb wrote:How to decide, which of these monetary policy shock to use?
viewtopic.php?f=23&t=5901&start=15#p39189
Hello Trubador,
I had asked you the below query earlier too. But I still not very clear on what to do. My research is heavily dependent on obtaining the Monetary policy shocks in a proper manner. Will MP shock be just the data present in one column (as per the explanation provided by you in column 68, see the sequence of variables below) or will I would need to add MP shocks present in every variable. I wanted to send you my Eviews workfile to have a look, but I am unable to attach either excel or Eviews workfile.
The sequence of my variables are Oil prices, Global Growth rate, Fed rate, Domestic GDP, WPI, M3, MP indicator, NEER, Stock market variable.
_____________________________________________________________________________________________
Parul
Parul
Hi Trubador,
I was able to attach the excel workbook. Pls see the highlighted column...under C68. Will I take the data under that column only as Monetary policy shock?
PB
PB
- historical decomposition_eviews.xlsx
- (204.08 KiB) Downloaded 603 times
Appreciate any help please.
Many thanks!!
Many thanks!!
How do you define the monetary shock from the theoretical standpoint? Fed rate, M3 or MP indicator? And you also need to decide which variable are you particulary interested in analyzing the impact of a monetary shock. GDP, NEER or stock market?
Hi trubador,
I have a quick question. Is it possible to use hdecomp on a Var that is not structural? And would that make sense ?
Thanks in advance
Thanks in advance
What do you think historical decomposition does? Yes, it is possible and would make perfect sense.
Hi Trubador,
When using the historical decomposition, I am looking to identify the SVAR using the Choleski Decomposition which you have provided
However, there does not appear to be any place to provide the casual ordering necessary to identify the SVAR using the Choleski Decomposition approach. (This is present on the other hand on the impulse analysis and variance decomposition pre-programmed eviews options)
How do I set my recursive ordering, similar to the eviews options, with your add in using the Choleski Decomposition?
Many Thanks
Many Thanks
valleire wrote:Hi Trubador,
Many Thanks
There is no need to use SVAR if you'll apply recursive ordering as it is the default factorization of regular VAR. However, you can obtain cholesky decomposition within SVAR framework as follows: viewtopic.php?f=5&t=13431#p46638
Hi everyone,
I also want to use this Historical decomposition add ins on the structual shocks of oil price.
So, I have 4 structural shocks : oil supply shock, aggregate demand shock, oil-market specific demand shock, and other shock.
As discussed before, the result of the add-ins is histmat matrix shows 20C. However, I am confused on how translate this result to graph.
I read this thread and find that C1-C5 represent the first shock, and so on.
Do I have to create graph manually by adding C1-C5 into Shock 1, etc?
Thank you. Really appreciate your answer.
Users browsing this forum: No registered users and 29 guests
