Numeric operator and string data
ral
Postby ral » Wed May 06, 2015 8:10 am
I am running a program that loads data into Eviews country by country and computes indices using the data. I added a series (PMI) that uses #N/A N/A to indicate missing values. The program works fine for one country (the United States), but I get the error message:
Numeric operator applied to string data function @MEAN in "GENR PMISTD=(PMI-@MEAN(PMI))/@STDEV(PMI)"
for the next country in the loop (the Eurozone) when I try to standardize PMI. What is odd is that the U.S. series also has missing values indicated in exactly the same way as the Eurozone -- i.e., it uses #N/A N/A.
Any idea about what is causing this problem?
Thank you.
Ron
Re: Numeric operator and string data
Postby EViews Gareth » Wed May 06, 2015 8:34 am
Hard to say without seeing it.
But you can probably convert the alpha series into a numerical one by using:
series pmis = @val(pmi)
ral
Postby ral » Wed May 06, 2015 8:48 am
Thank you for the quick reply. I get an error with the @val function:
Numeric argument passed to string @VAL function in "SERIES PMI1=@VAL(PMI)
This presumably happens because there are non-missing numerical data included in the series.
The Excel spreadsheet and the program are attached. The relevant sheets in the workbook are us_eviews and ez_eviews, and the PMI data are in column H.
You can also see in the Eviews workfile that Eviews recognizes the PMI data as a series for the US and as alphanumeric for the Eurozone. And yet both PMI series are, as far as I can tell, identically formatted in the spreadsheet.
Thanks again for your help.
Ron
cai_pmitest.prg
(5.67 KiB) Downloaded 46 times
cai_data.xlsx
(1.35 MiB) Downloaded 82 times
Postby EViews Gareth » Wed May 06, 2015 9:00 am
use:
   import(type=excelxml) {%excelname}  range={%x}_eviews types=(w, w, w, w, w, w,w, f, w, w) @freq m %start
ral
Postby ral » Wed May 06, 2015 9:08 am
I replaced this line in the program:
import(type=excelxml) {%excelname} range={%x}_eviews @freq m %start
with this line:
I get this error now:
Syntax error: invalid format string in "IMPORT(TYPE=EXCELXML) CAI_DATA.XLSX RANGE=US_EVIEWS TYPES(W, W, W, W, W, W, W, F, W, W) @FREQ M "1986M1""
And interestingly the program runs fine when I include the PMI series from Japan.
Thanks.
ral
Postby ral » Wed May 06, 2015 1:56 pm
I solved the problem. My program worked for some countries but not others, and there did not appear to be a systematic pattern governing when it did not work. The issue may have something to do with Excel rather than Eviews.
I inserted this logical test into the cells from which I was loading the data into Eviews:
=if(istext(A1),NA(),A1)
It tests whether the entry in A1 is text. If so, the command assigns the cell #N/A, which Eviews recognizes as a missing value. Otherwise, it assigns the cell the numerical value contained in cell A1.
Users browsing this forum: Bing [Bot] and 4 guests
