BayesLinear - Linear Gaussian model estimated using MCMC
AVossmeyer
Postby AVossmeyer » Wed Sep 03, 2014 1:19 pm
This thread is about the add-in BayesLinear. This add-in estimates a linear Gaussian model using Gibbs sampling. The add-in requests the user input the dependent variable and regressors. The user may select default or custom options for the priors, the number of MCMC draws, and the burn-in sample. The output is a table that reports posterior means, standard deviations, and 95% credibility intervals. In addition, histograms of the draws are displayed.
Please let me know if there are any questions or comments.
Thank you,
Angela Vossmeyer
trubador
Did you use forum search?
Re: BayesLinear - Linear Gaussian model estimated using MCMC
Postby trubador » Wed Sep 03, 2014 2:33 pm
This is a very nice and useful add-in. Thanks for sharing.
Postby startz » Wed Sep 03, 2014 2:58 pm
When I try to open the documentation, I get the following error message.
Postby EViews Gareth » Wed Sep 03, 2014 3:25 pm
Slight bug in the installer. A new version has been posted.
Postby startz » Wed Sep 03, 2014 3:54 pm
A very nice addition.
Two minor points:
(1) In the "Burn-in must be a" error message "positive" is misspelled.
(2) Ctrl-L doesn't work in the fields. I imagine this is not specific to this add-in.
Postby EViews Gareth » Wed Sep 03, 2014 4:03 pm
(2) is a limitation of the EViews programming language - CTRL-L doesn't work in program generated dialogs.
AVossmeyer
Postby AVossmeyer » Wed Sep 03, 2014 4:21 pm
Thank you for the comments and catching the error message.
- Angela
mrafei
Postby mrafei » Fri Dec 05, 2014 2:23 am
Dear colleagues,
when i want to estimate for a linear model and I want to determine the prior, in order to customize them I could not choose any specific numbers for its 4 options(Means and standard errors).
I would be glad if any of you have comments for my problem and give me an example.
lsbb21
Postby lsbb21 » Thu Jul 11, 2019 10:56 am
Hello, thank you for this great add-in. I would like to know what are the parameters chosen for the prior distributions on the default setting. Thank you very much.
Return to “Add-in Support”
