Hi i have this excel file and this workfile after stacked. I followed the step to stack the data but when I want unstacked as you explain in the topic "how to enter panel data in a workfile" I can´t do it .Could you help me?
I want evaluate the evolution of PBI and IA over the years in the diferent countries. Specifically my problem is how I can structure this excel file in eviews like panel data
thanks
how can I do to structure a panel data in a worfile
- excel.png (266.61 KiB) Viewed 8249 times
- evies.png (153.51 KiB) Viewed 8249 times
Re: how can I do to structure a panel data in a worfile
Post the actual data files, rather than pictures of them.
here are the real files
- beforestacked.WF1
- this is the workfile before stacked
- (44.68 KiB) Downloaded 316 times
- cuadro stacked.WF1
- the workfile after stack . I use pr series like stacking identifiers
- (131.23 KiB) Downloaded 314 times
- cuadro IACE.xls
- excel file
- (89 KiB) Downloaded 329 times
I'm going to assume that you want the dates to be the last part of the period (i.e. pr1990-92 will become simply 1992).
You appear to have some data problems with Saint Kitts, Saint Lucia and Saint Vincent. They have two IA variables, rather than an IA and a PBI.
Assuming you fix those, then the following code should do it for you:
wfopen "cuadro iace.xls"
pagestack pr?
series year = @dateval(@right(var01,2), "YY")
pageunstack variable paises year
pagestruct @date(year) paises
delete pr
rename pr* *
Thanks Gareth! The dates are an average between these years so if is posible i would like don´t change de name of the series.I have to do something different in order to not change the names of these series? . About Saint Kitts, Saint Lucia and Saint Vincent I made a mistake when I wrote but the data are one cell pbi and one cell ia.
If you want to use any time/date functionality in EViews, you're going to have to keep them as a single year.
ok no problem! really thanks
I have (2275/5) 455 cross-sections. with 20 years of data and 5 data series (Leverage, Growth, Tang, Size, Profit)
I have got the same problem. I followed the steps of stacking from the other thread as well. Only when I want to unstack using 'variable' as series name, and 'akey' and 'id01' (also tried var01) as observation identifiers I get the error 'ID series do not uniquely identify workfile observations'. I checked my data and could not find any duplicate data so far, is there a way to check what causes this error. (I also replaced all my blanks with zeros as in the current file)
Could anyone help me out?
Thank you in advance,
Philip
Philip
- Panel Data.xlsx
- (394.23 KiB) Downloaded 340 times
You appear to have duplicates for C000014614, C000014622, C000014759, C000014768.
Dear Gareth,
Really appreciate your help. It worked, thank you
Users browsing this forum: No registered users and 22 guests
