Saving Program within Workfile
fmgoto
Postby fmgoto » Wed May 06, 2009 12:16 pm
I usually run an Eviews code by clicking New/File/Program and hitting "Run". However, I need to store these programs (with minor changes) every time I run each program. I wonder if there is any way I could self-save the program I ran (or embed it within the same workfile Text object).
Thank You, Fabio
Re: Saving Program within Workfile
Postby EViews Gareth » Wed May 06, 2009 12:39 pm
You cannot save a program in a workfile (although you could copy the text into a text object and save that). However you can save the program file itself to disk (by clicking save).
fmgoto
Postby fmgoto » Thu May 07, 2009 11:47 am
Gareth,I need a command so that the program will save itself. Thank You!
Postby EViews Gareth » Thu May 07, 2009 11:49 am
There isn't one.
And since programs can't modify themselves, what would be the point in saving themselves?
smr01
Postby smr01 » Tue May 12, 2009 2:16 pm
You could try a hack like this:
1) Make another program to just save the program and workspace.
2) Write a .bat file, ie windows script file, to run your first program and then the new program to do the saving.
i.e. The bat file contains.
xxx.prg
xxy.prg
The bat file will wait for the fist program to finish before runing the second. I use this all the time.
Users browsing this forum: No registered users and 15 guests
