Eviews 5 with Windows 8?
For questions of any nature based on EViews 5 or earlier versions of EViews.
jjjungle
Postby jjjungle » Tue Nov 13, 2012 11:04 pm
I just got a new laptop that has Windows 8.
I have an old version of Eviews, version 5.
I tried installing Eviews5 onto the laptop. It installed ok but won't run. Will it work with Windows 8?
Re: Eviews 5 with Windows 8?
Postby EViews Gareth » Tue Nov 13, 2012 11:34 pm
Not sure if we've tried it, but I'd be surprised if it didn't work.
Erikamagz
Postby Erikamagz » Tue Nov 20, 2012 11:00 am
I'm having the same problem with my computer. Is there some kind of driver missing or something?
jasonrobards
Postby jasonrobards » Sat Apr 27, 2013 11:52 am
Having the same problem - I installed Eviews 5 on a Windows 8 machine. Install worked fine and icon appears on desktop, but programme won't start/open. Contacted Eviews support and was told "There are no known issues, and I have EViews 3,4,5,6,7 and 8 running on Windows 8 x64." Has anyone solved this?
Postby EViews Gareth » Sat Apr 27, 2013 1:53 pm
It appears as though sometimes it works, and sometimes it doesn't.
It is true - I have EViews 3-8 installed on my current Win 8 x64, but it certainly looks as though some people can't get it to run.
Since EViews 5 was released over a decade before Windows 8, it isn't particularly surprising.
dpgoldman
Postby dpgoldman » Fri Jun 07, 2013 7:59 am
Do you consider it Eviews' responsibility? At very least you should offer a free upgrade to a version that does run on Windows 8. I can't get mine to run, either.
Postby EViews Gareth » Fri Jun 07, 2013 8:59 am
I don't believe there is a responsibility to ensure that all versions of EViews will run on all PCs for ever more, no.
We do have a responsibility to ensure the current version of EViews will run on the current platforms we say it is supported on.
chokin
Postby chokin » Fri Apr 04, 2014 5:31 am
I wonder if this thread has been closed already as I'm experiencing the same kind of problem--Eviews 5 on Windows 8. Any patch or suggestion on how to address this issue?
Postby EViews Gareth » Fri Apr 04, 2014 6:30 am
EViews 5 will not run on Windows 8.
Return to “EViews 5 and Earlier”
