Forecasting a series without regressing
For questions of any nature based on EViews 5 or earlier versions of EViews.
thomaskm
Postby thomaskm » Thu May 24, 2012 4:53 am
Dear all,
I'm on Eviews 5 and i have a problem with forecasting. I want to see the Mean Root Squared Error for two series, namely
a) Overnight Interest rates
b) Taylor-rule with prespecified coëfficients.
I did some googling and it seems as if everytime you want to do a forecast, Eviews wants to estimate the coefficients first. I already know the coefficients i want to use, and hence, want to skip this feature. So basically: i want to do a forecast without regressing first. Can anyone help me with this?
Thanks in advance,
Kind regards,
Thomas Kooiman.
Re: Forecasting a series without regressing
Postby EViews Gareth » Thu May 24, 2012 7:52 am
You'll have to do it manually.
series y_f = coef(1)+coef(2)*x+coef(3)*z
etc..
thomaskm
Postby thomaskm » Fri May 25, 2012 2:15 am
Thank you kindly for your response. If i understand what you're saying i need to construct a serperate series that contains all the coefficients and variables that are in the Taylor rule. After that I do a regression with command
ls overnight_int overnight_int_taylor
and proceed with a forecast..
Postby EViews Gareth » Fri May 25, 2012 6:33 am
No, I'm just saying you construct the forecast directly by hand.
thomaskm
Postby thomaskm » Wed May 30, 2012 2:25 am
Could you please clarify how exactly this is done? I appreciate your answers thusfar, but they haven't enabled me to figure out how to do this.
The following screenshot depicts the two series for which i want to know the root mean squared error.
Could you tell me the specific code on how to do this in this instance? If I know that i can continue to do it for the rest of my dataset.
Thanks a bunch in advance!
Postby EViews Gareth » Wed May 30, 2012 7:04 am
I'm confused. What are you trying to do? Where do those two series fit into the forecast you're trying to do?
thomaskm
Postby thomaskm » Wed May 30, 2012 7:13 am
Yes, I think i've been unclear. My apologies.
I think my use of 'forecasting' wasn't right, i don't think i want to forecast anything.
All i want to do is the following: calculate the RMSE for the two series depicted in the graph. So: for overnight_int and overnight_int_taylor, for the entire period (1991Q1-1998Q4). That's it. Hope this clears up what i'm asking.
Postby startz » Wed May 30, 2012 7:18 am
Subtract one from the other and look at the standard deviation?
Return to “EViews 5 and Earlier”
