Computing a Wald Test in a VAR
Dear E-Viewer,
I want to do a Granger Non-Causality test in EViews within a VAR --- but --- I want to exclude the last lag in doing so. That means I just want to test whether the coefficients a_1, ... a_(p-1) are significantly different from zero. I do not want to include a_p in this test.
Any suggestion how this is easily done?
I am not that fit in Eviews language, so writing a proc myself is no option. I have actually never written anything in that language (not yet, at least).
Any help is highly appreciated!
Love,
Anna
Love,
Anna
Re: Computing a Wald Test in a VAR
Convert the VAR into a System (by clicking on Proc->Make System, then choosing either of the ordering options). Then you can perform a Wald Test from the View->Coefficient Tests menu.
Wow, thanks for the quick answer! Highly appreciated!
Another short one: is there any way to abbreviate c(1)=c(2)=....=c(10000)=0, like in the lag notation where we would write varname(-1 to -1000)? Something like c(1 to 12)=0 or so?
Kisses
Anna!
Kisses
Anna!
hai! Anna tx a lot , i hv bn looking for this procedure for a long tm. tx
Hi Gareth (or someone else who may know).
Ive had the same problem, only EViews wont allow me to estimate a Wald statistic from a system - I get the error message 'System estimates are not valid."
Does this work in EViews 6?
Thanks for the help,
Simon
Simon
Yes it does work in EViews 6. You have to estimate the system first though.
Great, thank you!
Is there any way to compute a Wald test where the equal sign is not used, such as c(1)<c(2) ? I have tried this, but it doesnt seem to work.
I'm the new user of E-views program. How can I test the toda yamamoto causality test in VAR system?
I need your help. Thank you very much..
sulistyo ningsih wrote:I'm the new user of E-views program. How can I test the toda yamamoto causality test in VAR system?
Exactly the same question? Is there anybody to help in testing the Toda-Yamoto causality in VAR system?
Direly need help!!
Trying to meet the deadlines, but not being able to estimate the model!!!
Four variables, Real Per Capita Income (y), Death Rate (d), Infant Mortality Rate (im) and Fertility Rate (f)
Anyone there to help?
There's nothing built in that will perform that test.
Alright. Thanks a ton for your response.
But for other tests such as Granger Causauty, if the model is estimated through syntax, rather than the inbuilt function, the results differ.
That's why I'm hesitating to run the model through syntax. Is there any guide/guidance available for learning to run that model on Eviews?
EViews Gareth wrote:Convert the VAR into a System (by clicking on Proc->Make System, then choosing either of the ordering options). Then you can perform a Wald Test from the View->Coefficient Tests menu.
Hey Admin....
Please do me a favor of quick response. 4 days left in paper submission.
I've estimated the VAR for Toda Yamamoto.....Now I need to execute WALD restrictions. But the method you referred, is not working in Eviews 5.0. Having converted the VAR into a system (either by Lag or by Variable), the VIEW menu contains only three options (System Specifications, Gradient and Derivatives, and Label). There is no COEFFICIENT TEST, from where I could estimate WALD.
Is there any way to estimate WALD on VAR in Eviews 5.0????
Direly need quick response please !!!!
You have to estimate the system first.
Users browsing this forum: No registered users and 53 guests
