EqBootstrap (bootstrap standard errors)
Moderators: EViews Moderator, EViews Gareth, EViews Esther
Postby EViews Gareth on Tue May 11, 2010 4:22 pm
This thread is about the EqBootstrap Add-in that bootstraps a linear least squares equation, allowing you to bootstrap either the standard errors or the point estimates. Note this add-in should not be used on weighted least squares or equations with ARMA terms.
Re: EqBootstrap (bootstrap standard errors)
Postby EViews Gareth on Tue May 11, 2010 4:26 pm
Note for equations with auto-series (i.e. expressions such as log(x) or x^2) as variables, the bootstrap variables type of bootstrap will only work if your version of EViews 7.1 is dated at 2010/05/11 or later. If it isn't (and you can check by clicking on Help->About EViews), you should download the latest patch.
Postby Erik on Fri Jun 25, 2010 11:17 pm
Good Morning,
I tried to install the add-in (I am using Eviews 7 and it was the first add-in I tried to install). After opening the file in Eviews a window opens (Binary Read - Step 1 of 3). It is not clear to me how I should proceed from there (or whether I should get to this window at all). I tried another add-in, with the same result. Can someone help?
Many thanks in advance,
Erik
Erik
Postby EViews Gareth on Fri Jun 25, 2010 11:35 pm
You need EViews 7.1
Postby javiersan on Mon Jun 28, 2010 10:09 am
Small typo in "repititions"?
javiersan
Postby EViews Gareth on Mon Jun 28, 2010 10:50 am
Indeed. Just fixed it and uploaded a new one.
Postby dvd.ceccarelli on Wed Feb 16, 2011 3:14 am
Dear Gareth,
I have to estimate a nonlinear LS with explicited coefficients:
d(dlp2) = c(1) + c(2)*(dlp2(-1)- (c(3)*lulc(-1)+ c(4)*mel(-1))) + c(5)*d(dlp2(-1)) + c(6)*d(lulc(-1)) + c(7)*d(mel(-1))
I have seen that bootstrao Add-in does not work. Is there a solution to run the bootstrap procedure? Thank you.
dvd.ceccarelli
Postby EViews Gareth on Wed Feb 16, 2011 8:33 am
The add-in currently only supports linear equations.
Postby ii69 on Thu Mar 10, 2011 7:44 am
Can anybody help me with one equation? It is pretty simple and I try to do boostraping for coefficients, yet I get a strange message: matrix or vector given non-positive dimension.
I have done the following:
set per 1999:1 2010:3
equation eqgexpo_ita.ls gexpo_ita grevo_ita
eqgexpo_ita.eqbootstrap(10000,SE,G,RES) gexp_ita grevo_ita
What I am doing wrong? How can I use this procedure properly?
ii69
Postby EViews Gareth on Thu Mar 10, 2011 9:10 am
You're not setting the number of bootstraps. You need to use the bs= option.
Edit: although that will fix your problem, it seems there is another issue in cases where you only have 1 regressor (such as your case). Although the bootstraps are still performed, the graph output will fail. We'll get that fixed at some point.
Postby EViews Gareth on Thu Mar 10, 2011 9:19 am
Just uploaded a new version that fixes the single regressor issue.
Postby yxr on Tue Aug 16, 2011 12:08 pm
Hi, there
I just want to ask how to carry out bootstrap simulation on GARCH model. since changing "LS" to "ARCH" in this programming does not work.
Thanks in advance
yxr
Postby EViews Gareth on Tue Aug 16, 2011 2:51 pm
As you noted, the Add-in doesn't support GARCH, so you'll have to program one yourself.
If all you want to do is bootstrap the exogenous variables in the GARCH estimation, it should be relatively straight forward. Anything more complicated will be, well, more complicated :D
Postby yxr on Tue Aug 16, 2011 11:47 pm
All right.
yxr
Return to Add-in Support
