What is the maximum number of regressors I can use in EVIEWS? I need to estimate a model with 750 autoregressive lags.
Thank you very much!
Maximum Number of Regressors in OLS
Re: Maximum Number of Regressors in OLS
The default size of the coefficent vector (C) is 750. However, you can always define your own coefficent vector prior to the estimation and use it instead.
Hello and thank you! how do I specify the size?
I mean that ok I created a coefficient vector with 1000 rows named cc. But trying to estimate an OLS from Quick-Estimate Equation with 1000 regressors I still get an error message. How can I do it?
Unfortunately you can no longer estimate an equation by list if you want to use your own coefficient vector. You have to estimate by expression.
EViews Gareth wrote:Unfortunately you can no longer estimate an equation by list if you want to use your own coefficient vector. You have to estimate by expression.
Dear Gareth, thank you for your reply.
I have created a vector named "CC" as the alternative coef vector with 1000 rows.
Typing:
ls price c coal(-1 to 800)
I get an error message...how can I instruct eviews to use the CC coef vector and avoid this error message?
As I said above, you can't specify by list (which is what you're doing there). You'll need to specify by expression:
and so on. Yes this is a mighty pain if you have to write out 1000 of them.
However it isn't hard to write a program that will do it for you. See below:
price = cc(1) + cc(2)*coal(-1) + cc(3)*coal(-2) +
create u 100000
series price = nrnd
series coal = nrnd
coef(1001) cc
%regs = ""
for !i=1 to 1000
%regs = %regs + " + cc(" + @str(!i) + ")*coal(-" + @str(!i) + ")"
equation e1.ls price=cc(1001) {%regs}
That is great! thank you very much!
Greetings. Gareth, plse unpack what the mini prog is doing. I am fascinated. In particular, the loop.
Regards, James Johnson
The loop is just building up a string.
First iteration
Second iteration
which is
and so on.
At the end %regs will be equal to
I then just use that in the regression:
First iteration
%regs = "+ cc(1)*coal(-1)"
Second iteration
%regs = %regs + "+ cc(2)*coal(-2)"
which is
%regs = "+ cc(1)*coal(-1) + cc(2)*coal(-2)"
and so on.
"+ cc(1)*coal(-1) + cc(2)*coal(-2) + cc(3)*coal(-2) + ........ + cc(1000)*coal(-1000)"
ls price=cc(1001) + cc(1)*coal(-1) + cc(2)*coal(-2) + cc(3)*coal(-3) + ...... + cc(1000)*coal(-1000)
Much thanks, Gareth. You are a good teacher. Many thanks to Perry for asking the question also.
James
James
Users browsing this forum: No registered users and 37 guests
