LDVHAC
EViews Esther
LDVHAC
Postby EViews Esther » Tue Sep 14, 2010 11:12 am
This thread is about the LDVHAC add-in that calculates heteroskedasticity and autocorrelation consistent (HAC) standard errors for limited dependent models such as probit and logit.
[Change log]
2011/05/23 Changed bandwidth options (E.g. User-specified bandwidth has no default value).
ramzan
Re: LDVHAC
Postby ramzan » Thu Nov 11, 2010 8:27 am
how to use theses add-inns
EViews Esther
Re: LDVHAC
Postby EViews Esther » Thu Nov 11, 2010 9:13 am
Inference in models which contain autocorrelation and/or heteroskedasticity of unknown form requires
covariance matrix estimators that can consistently estimate the covariance of the model parameters.
This add-in will provide you suitable heteroskedasticity and autocorrelation consistent (HAC) estimators.
To apply the add-in, you can take the following steps.
(1) Download *LDVHAC*
(2) Click *Add-ins* button
(3) Click *HAC covariance matrix calculation for LDV models*
ramzan
Re: LDVHAC
Postby ramzan » Fri Nov 12, 2010 8:24 am
there is no add-inns menu and i have Eviews 7
trubador
Did you use forum search?
Re: LDVHAC
Postby trubador » Fri Nov 12, 2010 8:35 am
ramzan wrote:i have Eviews 7
viewtopic.php?f=23&t=2122#p7174
KarinL
Re: LDVHAC
Postby KarinL » Wed Mar 09, 2011 5:31 am
I just stumbled across the range of add-ons provided for eviews7.
For what object is this add-on intended?
I'm estimating a specific garch -model by MLE, i.e. using a LOGL object and would like to estimated robust t-stats with HAC standard errors.
Is this add-on applicable for my case?
Thanks in advance.
Re: LDVHAC
Postby EViews Gareth » Wed Mar 09, 2011 8:55 am
This Add-in is for equation objects - i.e. estimation using the built in probit/logit procedures.
KarinL
Re: LDVHAC
Postby KarinL » Wed Mar 09, 2011 9:26 am
ah, ok. So, then there is no way to use the add-in in my particular case?
Re: LDVHAC
Postby EViews Gareth » Wed Mar 09, 2011 9:31 am
Indeed.
Return to “Add-in Support”
