Data axis graph bug?
Postby startz » Sat Aug 14, 2010 3:21 pm
...This one seems so unlikely that I must be misunderstanding something.
Graph an annual series. Freeze it. options/Axes & Scaling/Data Scaling/Bottom Axis/User specified
Choose min and max to show only a portion of the axis. (If smpl is 10 20 choose 5 12.) OK
Nothing changes.
EViews Pamela
Re: Data axis graph bug?
Postby EViews Pamela » Wed Sep 22, 2010 11:50 am
This dialog is a little confusing. You are changing the bottom axis via the Data page, not the Obs/Date page. So you are setting attributes that would apply anytime you have a data series assigned to the bottom axis (which I assume you currently don't). If you assign your series to the bottom axis, you will see the changes are applied.
Postby startz » Wed Sep 22, 2010 1:02 pm
Thanks. :)
