Dear Support,
When I print a large spool into a PDF in Eviews 13 it crashes (using microsoft to PDF). When I use Eviews 12 it prints the same spool without objection. I managed to reproduce the error on another PC with Eviews 13. I use the microsoft to PDF as it can scale the size of the spool. If i use the "save spool to disk" command, I succeed to save the pdf but the format is not adjusted to the page size.
The spool in question is quite big and contains several large tables and hunderts of graphs.
Kind regards,
Michel Geller
EVIEWS 13 crashes on printing spool in pdf
Re: EVIEWS 13 crashes on printing spool in pdf
We'll need a copy of the workfile that has the spool so we can reproduce the crash on our end. Any way you can share it with us?
Also, which is the build date of your EViews 13?
Users browsing this forum: No registered users and 19 guests
