I am estimating an equation with FUNCOEF. I get the results, but when I try to get the fitted series (both via menu and code) I get a syntax error. I am using Eviews 12 Jun. 8 build.
thanks a lot
forecast with functional coefficients
Re: forecast with functional coefficients
Hi!
Would you mind submitting your workfile/program? It will help in diagnosing and fixing the bug.
Mirza
Mirza
Sure, please look at the Q page, all equation except _thr
thanks
thanks
- rstarhf.wf1
- (854.1 KiB) Downloaded 124 times
I believe I understand why you're getting that message. In the estimation dialog, under "Functional coefficient series", you're providing multiple series. The functional coefficient estimator expects a single series here. Although you're getting estimation results, they are based only the first series in the list you're providing. Hence, to get forecasting to work, you'll have to re-estimate those equations with a single functional coefficient series spec.
I hope this helps.
I hope this helps.
Thanks a lot.
Users browsing this forum: No registered users and 15 guests
