Graph option gridcust in programs not working properly in individual charts for daily panels
mamo
Postby mamo » Thu Nov 26, 2020 9:26 am
Dear Eviews team,
I use EVIEWS 11 Sept 2019 built, 64 bit.
The graph option "gridcust" does not work properly in daily panels when invoked in a program.
This happens with daily panels when individual charts for panels within the graph are created (option "panel=i")
The manual grid adjustment via the menu works as expected, and the gridcust option works also in programs applied to quarterly frequency data, or - for any data frequency - when the graph has been generated using the panel options "combined" or "stacked".
See example below code
Kind regards
mamo
wfcreate d7 01-01-2000 02-28-2000 2
series x=nrnd
freeze(mode=overwrite, chart_panel_i) x.line(panel=i)
chart_panel_i.options gridcust(obs,1)
' Grid not adjusted
show chart_panel_i
freeze(mode=overwrite, chart_panel_c) x.line(panel=c)
chart_panel_c.options gridcust(obs,1)
' Grid adjusted, ok
show chart_panel_c
freeze(mode=overwrite, chart_panel_s) x.line(panel=s)
chart_panel_s.options gridcust(obs,1)
' Grid adjusted, ok
show chart_panel_s
Re: Graph option gridcust in programs not working properly in individual charts for daily panels
Postby EViews Jason » Tue Dec 01, 2020 6:51 pm
Thank you for the report and program. We were able to replicate the issue and will be investigating the issue.
Postby EViews Jason » Wed Dec 02, 2020 2:30 pm
The problem was the 'options' proc did not work in multi-graph situations. In your example, chart_panel_i was a multi graph whereas chart_panel_s and chart_panel_c were single graphs. The problem therefore appeared in only chart_panel_i.
The problem existed in non-panel workfiles as well.
Thanks to your example were able to quickly identify the problem.
It will be fixed in the next patch.
Users browsing this forum: No registered users and 21 guests
