"close" command in pyeviews
hasan1
Postby hasan1 » Tue Aug 27, 2019 9:51 am
I am unable to pass the "close" command from pyeviews to Eviews. Bunch of other commands work smoothly.
import pyeviews as evp
eviewsapp = evp.GetEViewsApp(version='EViews.Manager.11', instance='new',showwindow=True)
evp.PutPythonAsWF(varlist, app=eviewsapp) #this works
evp.Run('run program.prg', app=eviewsapp) #this works
evp.Run('close program.prg', app=eviewsapp) #this does not work
evp.Run('close @prg', app=eviewsapp) #this does not work
evp.Run('wfsave(2) Model', app=eviewsapp) #this works
Re: "close" command in pyeviews
Postby EViews Steve » Tue Aug 27, 2019 10:05 am
I used a small test program like this one:
wfcreate a 1991 2000
series x = rnd
series y = rnd
Then did the following in python using pyeviews:
Python 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 16:07:46) [MSC v.1900 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> eviewsapp = evp.GetEViewsApp(version='EViews.Manager.11', instance='new', showwindow=True)
>>> evp.Run('run test.prg', app=eviewsapp)
>>> evp.Run('close test.prg', app=eviewsapp)
And the test program window closed just fine in my EViews 11.
Can you try this on your setup to see if it works?
Postby EViews Steve » Tue Aug 27, 2019 10:07 am
Also, make sure you have the latest EViews 11 patch installed.
