@dateadd error
ErikG
@dateadd error
Postby ErikG » Mon Jan 29, 2018 1:37 am
WfCreate C:\temp\temp.wf1 m 1980 2020
!da = @DateAdd(736722,1,"mm")
@UiPrompt(@Str(!da))
Returns NA
Other numbers such as 3000 work fine.
Eviews 10 jan 17 2018 build
Regards
/Erik
ErikG
Re: @dateadd error
Postby ErikG » Mon Jan 29, 2018 2:01 am
I now see that this has to do with the current date: 29th of january. Since the 29th of february does not exist, @dateadd returns NA. I will write up a workaround:
If !da = Na Then
   !da = @DateAdd(736722,15,"dd")
EndIf
dman
Re: @dateadd error
Postby dman » Wed Jan 31, 2018 10:01 am
Ran into a similar issue today 01/31/2018.
I'm not adding days, but subtracting them off @now. As long as the target month is 31-days long it works. For 30-day months it doesn't.
@datestr(@dateadd(@dateval("1/31/2018"),-4,"mm"),"yyyy[q]q")
results in "?"
substituting -4 to -1 (so that the result is December'17) works.
Seems like a bug alright.
Re: @dateadd error
Postby EViews Gareth » Wed Jan 31, 2018 10:19 am
Not a bug - same issue as before.
You're taking 4 months from January 31st. That equals September 31st. There is no such thing as September 31st, so the result is not available.
