Eviews has crashed numerous times upon the following:
- Equation specified containing AR term(s)
- Attempting a Forecast using the Structural part of the equation only
I get "Eviews 9.5 has stopped working A problem caused the program to stop working correctly..."
This has happened more times than I can count, as this is a common process for me, but did not occur with prior versions of Eviews. Overall Eviews 9.5 is not as stable as Eviews 7.
Any assistance/ideas would be much appreciated. I'm running 9.5 64-bit and am a long-time Eviews user.
Jonathan
Eviews Crashing w/ Structural Only Forecast
- TestFile.wf1
- (83.68 KiB) Downloaded 246 times
Re: Eviews Crashing w/ Structural Only Forecast
Is your copy up to date?
I believe so. My impression is that Eviews checks for updates every time it opens. In any event, I just checked for updates, and it is up to date. Thanks.
ok, we'll take a look. (As a side note - it may be some time to issue a fix to 9 since we only update 10 on a regular basis).
Thanks, Gareth. When do you think you can look into this...(e.g., at least confirming you can recreate the problem)?
I can confirm we can recreate the issue.
We'll probably issue a fix for 10 (where it still exists) within a week or two.
No ETA on 9.
No ETA on 9.
Ok. Thanks. I'm amazed this hasn't come up earlier...I tend to use that feature frequently (and should have alerted Eviews a long time ago). I'll stay tuned.
Users browsing this forum: No registered users and 26 guests
