series omitted when storing to Aremos database
Posted: Tue Aug 01, 2017 11:04 am
This bug can cause an error whereby some series are omitted when storing to an Aremos databank.
As currently written, the code below should produce the error.
The probability of error appears to be a function of 2 things:
(1) the alphabetical order of series being stored (the more out of order, the higher the probability of error)
(2) the number of series being stored (the more series, the higher the probability of error)
Thus, there are 2 independent ways to modify the code to prevent the error:
(1) Currently, %half2 is stored before %half1. If you reverse the order, the error should go away.
(2) Currently, there are 40 series in each half (total of 80). If you reduce it to 20 in each half (total of 40), the error should go away.
I am using this version:
EViews 9.5 (64-bit)
Enterprise Edition – Jul 11 2017 build
EViews 9.5 (64-bit)
wfcreate(wf=work, page=a) a 2000 2030
%half1 = ""
for !i = 11 to 50
%half1 = %half1 + "a" + @str(!i) + " "
%half2 = ""
for !i = 51 to 90
%half2 = %half2 + "a" + @str(!i) + " "
for %s {%half1} {%half2}
genr {%s} = 1
if (@fileexist("bank.bnk") = 1) then
dbdelete bank
endif
db(type=aremos) bank
store(d=bank) {%half2}
store(d=bank) {%half1}
close @db
dbopen(type=aremos) bank
