I use Eviews version 9.5, 17 March 2016 built with Windows 7.
I found that the function "@convert" to convert a group to a matrix causes Eviews to break if a sample is provided as a function argument to @convert. This happens in both cases, with @convert being called in the command window or within a program.
The code below with the last line uncommented lets Eviews pop up a window saying "Eviews 9.5 has stopped working. A problem caused the program to stop working correctly. Pease close the program", and Eviews breaks down then.
'Create workfile with some random series 'and collect the series in a group
wfcreate(wf=test) q 1980Q1 2015Q4
!nseries=5
group gr
for !i=1 to !nseries
series x{!i} = nrnd
gr.add x{!i}
'The following conversion of the group into a matrix works:
matrix mat=@convert(gr)
' But providing a sample to the @convert function as in the following line makes eviews break:
' matrix mat=@convert(gr, "2000Q1 2015Q4")
Best,
mamo
