Something has happened with the "import"-command between version "Aug 25 2015 build" and "Sep 14 2015 build".
When running the code below in version "Aug 25 2015 build" (and in Eviews8) then the string "list" = " abc1 def1 gih1 abc2 def2 gih2".
But when running it in "Sep 14 2015 build" the string "list" is empty? Is it a bug or is the code wrong?
Regards Johan
WfCreate u 1 100
' Creating a temporary text-file
Text t
t.append "abc1"
t.append "def1"
t.append "gih1"
t.append "abc2"
t.append "def2"
t.append "gih2"
t.save(t=txt) c:\temp\Output
Delete t
' Reading txt-file
Import c:\temp\Output.txt
String list
For !i = 1 To series01.@last
list = list + " " + series01(!i)
Next
Show list
