Mixed frequency graphs bugg?
johansamuelsson
Contact:
Postby johansamuelsson » Mon Aug 31, 2015 2:40 am
I have some problem using graphs with two different frequencies in Eviews 9 that worked fine in 8. When running the example below the two graphs get the exact same appearance in Eviews 8. But when running the code in Eviews 9 the series "tmp2", "tmp3" and "tmp4" in the graph "g2" are incorrect. Note that the series "tmp1" is correct in "g2".
I have the same options under "General Options" / "Series and Alphas" / "Frequency conversion" in 9 and 8 (don't think it matters).
Any ideas?
Versions:
Eviews 9: Standard Edition - Aug 25 2015 build
Eviews 8: Standard Edition - Aug 18 2015 build
Regards Johan
WfCreate(page=d5) d5 2010 2015
PageCreate(page=m) m 2010 2015
PageSelect d5
Series tmp1
Series tmp2
Series tmp3
Series tmp4
tmp1.adjust = 1 .. 10
tmp2.adjust = 1 .. 15
tmp3.adjust = 1 .. 20
tmp4.adjust = 1 .. 25
PageSelect m
Series tmp5
tmp5.adjust = 1 .. 30
Smpl 2010 2015
Graph g1.line M\tmp5 D5\tmp1 D5\tmp2 D5\tmp3 D5\tmp4
Graph g2.line D5\tmp1 D5\tmp2 D5\tmp3 D5\tmp4 M\tmp5
Show g1 g2
Re: Mixed frequency graphs bugg?
Postby EViews Jason » Thu Sep 03, 2015 12:25 pm
johansamuelsson
Contact:
Postby johansamuelsson » Wed Sep 16, 2015 11:05 pm
Is there any patch soon that will fix this, we have some problem with our external (and internal) presentations (graph with mixed frequencies), and we'd rather not reinstall Eviews 8?
Regards Johan
Postby EViews Jason » Thu Sep 17, 2015 8:27 am
Should be fixed in the 9.14.15 patch. Are you not seeing that?
johansamuelsson
Contact:
Postby johansamuelsson » Fri Sep 18, 2015 2:02 pm
It works now, thanks
Regards Johan
Users browsing this forum: No registered users and 32 guests
