In sample and out of sample test
Postby EViews Gareth » Sat Aug 27, 2011 8:00 am
You'll have to be more specific. What are you trying to test?
sweivE
Re: In sample and out of sample test
Postby sweivE » Sun Aug 28, 2011 7:39 am
Let's say your data sample is 1995q1 2010q4
If I want to test a model used for forecasting, I would estimate it for a sub-sample that leaves me with enough out-of-sample observations, such as 1995q1 2006q4.
For in-sample test, estimate the equation, and check the statistics like RMSE, MAE, etc, that compares the fitted to the actual.
For out-of-sample, you need to use the estimated equation to produce n steps ahead forecasts, and compare them to the actuals.
For example, for a 1 step ahead forecast you will run the regression 20 times (20 quarters) and get 20 forecasts. Once you have a series of 20 forecasts you can use it and the actuals to compute an out-of-sample RMSE, MAE, etc.
The technical way of doing this is by writing a recursive rolling regression which adds one observation at a time creats a one step ahead forecast and stores it to a series
I have prepared a code for what I wrote above. It is modified for my uses, but hopefully you will be able to get the point.
rolling.prg
(4.58 KiB) Downloaded 2340 times
hichbenn
Postby hichbenn » Tue Sep 20, 2011 6:52 am
sweivE wrote:Let's say your data sample is 1995q1 2010q4
My friend,
its exactly what im looking for. i would like to estimate a var model for every subsample and calculate the forecasting for h horizons, then calculate the RMSE for each horizon.
Is it what your program do?
thanks alot
dongyadu
Postby dongyadu » Mon Oct 03, 2011 6:23 am
Hi SweivE
I am trying to calculate the mean squared prediction error for the one month step ahead out of sample forecasting with rolling window forecasting and recursive window forecasting scheme. But, I don't know how to write the code following with below program. Please can you help me? Many Thanks
    'create some data
    create u 100
    series y=nrnd
    series x1=nrnd
    series x2=nrnd
    series z=nrnd
    'run rolling regression
    ' set window size
    !window = 20
    ' set step size
    !step = 1
    ' get size of workfile
    !length = @obsrange
    ' declare equation for estimation
    equation eq1
    'calculate number of rolls
    !nrolls = @floor((!length-!window)/!step)
    'matrix to store coefficient estimates
    matrix(3,!nrolls) coefmat ' where 3 is the number of coefficients
    'series to store forecast estimates
    series fcast
    'redundant series for catching start and end points
    series ser = 1
    %start = @otod(@ifirst(ser))
    %end = @otod(@ilast(ser))
    'variable keeping track of how many rolls we've done
    !j=0
    ' move sample !step obs at a time
    for !i = 1  to  !length-!window+1-!step step !step
       !j=!j+1
       ' set sample for estimation period
       %first = @otod(@dtoo(%start)+!i-1)
       %last = @otod(@dtoo(%start)+!i+!window-2)
       smpl {%first} {%last}
       ' estimate equation - where the equation is y=c(1) + c(2)*x1 + c(3)*x2
       eq1.ls y c x1 x2
       ' store coefficients
       colplace(coefmat,eq1.@coefs,!j)
       ' 4-period-ahead forecast
       %4pers = @otod(@dtoo(%start)+!i+!window-1)      'start point
       %4pere = @otod(@dtoo(%start)+!i+!window+2)   'end point: %4pere - %4pers +1 = 4
       if {%end} < {%4pere} then   'check whether the forecast end point is greater than the workfile end point
          return
       endif
       ' set smpl for forecasting period
       smpl {%4pers} {%4pere}
       ' forecast with command *forecast* (see also *fit*)
       eq1.forecast(f=na) yf
       ' set sampl to obtain the 4th period observation
       smpl {%4pere} {%4pere}
       ' store forecasts
       fcast = yf
    smpl @all
    show coefmat
    show fcast.line
    d(noerr) ser
Dongya
Faqeer1
Postby Faqeer1 » Sun Apr 10, 2016 11:30 pm
For example, for a 1 step ahead forecast you will run the regression 20 times (20 quarters) and get 20 forecasts. Once you have a series of 20 forecasts you can use it and the actuals to compute an out-of-sample RMSE, MAE, etc.????
== www.solitairecardgame.info ==
