Graph shade for left/right axis across different sample periods
handwashing
Postby handwashing » Sun Jul 19, 2020 8:08 pm
Hi EViews Team!
It would be nice if the draw(shade, left/right) command can be modified so that the shaded values can be modified across different sample periods. Please let me know if this is already possible. Something like this would be pretty convenient:
graph01.draw(shade, left) 1 2 2018Q1 2018Q3
graph01.draw(shade, left) 4 5 2018Q4 2019Q3
Re: Graph shade for left/right axis across different sample periods
Postby EViews Jason » Thu Nov 12, 2020 6:23 pm
I am not clear as to what you are asking based on the examples you have given. In your example you have
What does the '1 2' refer to?
v02max
Postby v02max » Wed Nov 22, 2023 7:09 pm
Would be interested to know if there is already a solution to this question?
The idea is to shade different ranges of the vertical axis for different samples. In this case, 2 3 and 1 2 can pertain to an inflation target range.
graph01.draw(shade, left) 2 3 2010 2016
graph01.draw(shade, left) 1 2 2017 2023
If I try this code, the shading will be done for 2010 2023 and for the entire 1 to 3 range instead of 2 to 3 for 2010 to 2016 and 1 to 2 for 2017 to 2023.
Users browsing this forum: No registered users and 25 guests
