ARDL bound test
Re: ARDL bound test
there is no Unrest linear trend in the menu of ARDL. it's been one year why?
1/can you add this case V (Unrest linear trend).
2/can you make easy way to import the cointegration regression output to the ols object (like ARDL estimation), that we can see the R^2 AIC HQ...DW ...etc, or to see it bellow the cointegration regression (inprove ouput cointegration regression).
3/the bouds test show critical value of F statistic for 4 CASES, in Pesaran & al: BOUNDS TESTING APPROACHES TO THE ANALYSIS OF LEVEL RELATIONSHIPS 2001 p 303 there is tree tabales of t-stistics for CASE I, CASE III, and CASE V. can you add this critical t-statistic for the bounds test.
kind regards.
kind regards.
Re: ARDL bound test
how can we do bound test in eviews 9 if first selected model for ardl has a serial correlation. Because for second best model for ardl we should appy it ,like earlier versions of eviews manual or I dont know how to do it in eviews with new approach. So if I select second model or the reason of seral correlation how can apply it and if estimate it like before should ı do wald test or does it have any new way to do it
Re: ARDL bound test
You can fix the lags at whatever values you want.
Users browsing this forum: No registered users and 17 guests
