bandwidth and the number of lags
RDS
Postby RDS » Fri Nov 08, 2019 3:41 am
I would like to know how I can infer the number of lags used for the bandwidth associated to the (long-run) variance estimator.
In running a system with GMM, I get the following output:
Included observations: 247
Total system (balanced) observations 3458
Kernel: Bartlett, Bandwidth: Variable Newey-West (2), No prewhitening
Simultaneous weighting matrix & coefficient iteration
Convergence achieved after: 1 weight matrix, 2 total coef iterations
Can you tell me if I can infer the number of lags from the Bandwidth (Variable Newey-West (2)).
Is it 2 the number of lags?
For your additional information, if I use the NW fixed option with 247 observations, I get the following, where the Bandwidth is 5.
Using the formula available here is rather complex to extract the number of lags: http://www.eviews.com/help/helpintro.ht ... 23ww155429
Kernel: Bartlett, Bandwidth: Fixed (5), No prewhitening
Re: bandwidth and the number of lags
Postby EViews Gareth » Fri Nov 08, 2019 7:58 am
Yes, 2 is the number of selected lags.
RDS
Postby RDS » Sat Nov 09, 2019 4:47 am
If I run an OLS regression, I get the following:
HAC standard errors & covariance (Bartlett kernel, Newey-West automatic bandwidth = 7.7735, NW automatic lag length = 4)
No d.f. adjustment for standard errors & covariance
If I apply a rule of thumb from the literature I get a Bandwidth = 4.7-4.9.
How does all this square? Thank you
RDS
Postby RDS » Tue Nov 12, 2019 3:41 pm
Possibly I was not clear.
If I run an OLS regression with 247 observations, I get the following
What is the number of lags that I can infer from the Bandwidth?
In the OLS case the number of lags seems to be associated with a bandwidth = 7.7735.
While when running a GMM, as you said, bandwidth = number of lags = 2.
Postby EViews Gareth » Tue Nov 12, 2019 4:33 pm
Sorry, I didn't notice you had a system. 5 is the bandwidth.
