Subroutine in a Loop EViews 4
For questions of any nature based on EViews 5 or earlier versions of EViews.
siebenkaese
Postby siebenkaese » Tue Nov 27, 2012 10:36 am
I am having problems calling a subroutine in a loop.
The code looks like this:
for !i=1 to 2
   %n = @str(!i)
   equation ar_{%n}.ls {%dep} ar(!i)
   ar_{%n}.makeresids ar_{%n}_res
   %res= "ar_{%n}_res"
   call autocorrelations
The subroutine creates a vector with the autocorrelation up to a prespecified lag. When I run the program I only get results for the AR(1). It seems like the command "call" stops the loop. If I remove the subroutine, everything is fine, but I obviously don´t get the vector with the autocorrelations.
Does the call command stop the loop or is there another problem ?
Return to “EViews 5 and Earlier”
