I am trying to get into eviews and especially what it can do in forecasting. I am trying to run a forecast for a known series ( ICI, 755 observations will be used for the forecast, the remainder of the 1254 observations will be used to judge the model ). It's quite simple what I am trying to do. I looked through the manual and found some code. I found this code below and understand most the code but I can't even get it to run, let alone evaluate it's correctness ( luckily I have matlab so if something is off, I can compare it )
I am Trying to construct Construct 1,2,3,4,5 ahead point forecasts for the sample period. Hence at each time T (T = 755, 756, . . . , 1254) I want to an forecast ICIT+h|T (h = 1, 2, 3, 4, 5), then I wan to re-estimate the AR(3) model repeatedly every 25 observations, 'using a 'moving 'window approach with a sample length of 755 observations of the ICI ( implied correlations index )
Any suggestions ? Is trying to solve it in this way even good ?
I also get an error saying @ifirst is an illegal or reserved name.
Perhaps you can help me or did something similar before and can show how you programmed this into this software.
'DATA is already in the series file which contains the ICI
'Program description
' I am Trying to contruct Construct one-, two-, three-, four and
'five-step ahead point forecasts for the sample period. Hence at each time T (T = 755, 756, . . . , 1254) I want to an forecast ICIT+h|T (h = 1, 2, 3, 4, 5), then I wan to re-estimate the AR(3) model repeatedly every 25 observations, 'using a 'moving 'window approach with a sample length of 755 observations of the ICI ( implied correlations index )
'Date last modified 12/03/12 03:25 am
' set window size
!window = 25
' set step size
!step = 1
' get size of workfile
!length = @obsrange
' declare equation for estimation
equation eq1
'calculate number of rolls
!nrolls = @floor((!length-!window)/!step)
'matrix to store coefficient estimates
matrix(4,!nrolls) coefmat ' where 4 is the number of coefficients
'series to store forecast estimates
series fcast
'redundant series for catching start and end points
series ser = 1
%start = @otod(@ifirst(ser))
%end = @otod(@ilast(ser))
'variable keeping track of how many rolls we've done
!j=0
' move sample !step obs at a time
for !i = 1 to !length-!window+1-!step step !step
!j=!j+1
' set sample for estimation period
%first = @otod(@dtoo(%start)+!i-1)
%last = @otod(@dtoo(%start)+!i+!window-2)
smpl {%first} {%last}
' estimate equation - where the equation is AR(3) model
eq1.ls ICI c AR(1) AR(2) AR(3)
' store coefficients
colplace(coefmat,eq1.@coefs,!j)
' 5-period-ahead forecast
%5pers = @otod(@dtoo(%start)+!i+!window-1) 'start point
%5pere = @otod(@dtoo(%start)+!i+!window+2) 'end point: %5pere - %5pers +1 = 5
if {%end} < {%5pere} then 'check whether the forecast end point is greater than the workfile end point
return
endif
' set smpl for forecasting period
smpl {%5pers} {%5pere}
' forecast with command *forecast* (see also *fit*)
eq1.forecast(f=na) ICIf
' set sampl to obtain the 5th period observation
smpl {%5pere} {%5pere}
' store forecasts
fcast = ICIf
smpl @all
show coefmat
show fcast.line
d(noerr) ser
