F-Statistic in 2SLS
F-Statistic in 2SLS
The 2SLS output provides the F-Statistic, is this the same as the first-stage f-statistic reported in Stata? They are providing different results, should this be the case? If so, can someone explain why? Thanks
Re: F-Statistic in 2SLS
It is not the first-stage F. It's the F-statistic for the hypothesis that all the coefficients except the intercept equal zero.
The EViews 2SLS output produces the F-statistic for the significance of the regressors in the 2SLS specification, not for the first-stage. Bearing in mind that I am not certain what Stata is doing, if they are producing an F-statistic based on the first stage, it would presumably be quite different.
I just noticed that Startz posted a reply to your original question. Coincidentally, I was going to provide you with a reference:
Startz, Richard, "Computation of Linear Hypothesis Tests for Two-Stage Least Squares," Economics Letters 11, 1983, pp. 129-131.
Wooldridge(2012) says you shouldnt conduct F-Tests using 2SLS because the R^2 is able to be negative.
Wooldridge suggests that there are other ways to conduct an f-test that avoids this problem and that most statistical software uses this wrap around. Does Eviews correct for this problem?
I'm not certain of which Wooldridge reference you are citing, nor his recommeded workarounds. The R2 form of F-statistics is an computational shortcut that one can use in certain, but not all, cases. EViews has never used this shortcut; the reference I provided above describes in great detail what we do.
Return to “EViews 5 and Earlier”
