It is possible to conduct principal component analysis using EVIEWs 5.1? If so, how is this done?
Ernest Cheung
Principal Component Analysis using EVIEWS 5.1
Re: Principal Component Analysis using EVIEWS 5.1
Create a group object with the series of interest, and select View/Principal Components... from the group menu.
EViews Glenn wrote:Note that if you want to save things, you should use Proc/Make Principal Components...
Should I use it for saving or for making things?
Gsm Repeater Is Useful Device For All Houses
Dropped calls. Gsm Repeater Is Safe For Our Health.
I'm not certain what you mean by "saving or making". The Proc/Make... routine will save the components in the workfile.
Return to “EViews 5 and Earlier”
