Hi, when I run the following line of code with any series, I still get the default setting "sic" for the information criteria. Any ideas? Thanks
seriesname.uroot(adf,trend,info=aic)
ADF test
Re: ADF test
If you run that line in a program, you'll see that it does, in fact, use the AIC.
Re: ADF test
Thanks Gareth, you are right. I was testing it on the command line.
Re: ADF test
A minority of commands don't behave the same way in the command line and in a program. Can be confusing/frustrating.
Re: ADF test
We'll make a note of this one and see how hard it is to get the dialog to read the command options.
Users browsing this forum: No registered users and 34 guests
